I packed a uConsole with a 35,000mAh battery and crammed in as much hardware as the chassis would physically hold. It’s all running Parrot OS and basically serves as a complete, handheld RF/pentesting lab.
Fifteen antennas, two Wi-Fi cards, a sub-GHz radio, and an SDR in a handheld that lasts a full workday and then some. Photos will do most of the work here, but here is the full breakdown of what it took to get this running.
The Hardware Inside
Battery/Power: Custom 35,000mAh pack made from 10x spot-welded 18650 LG cells, running through a 20A discharge BMS. I added an aluminum capacitor to smooth out the power delivery, tying into a HackerGadgets battery board.
The Brains / Expansion: uConsole AIO V2, which packs an insane amount of built-in hardware: RTL-SDR, LoRa, GPS, RTC, a built-in USB Hub, USB 3.0, and an RJ45 Ethernet port.
Networking: 2× AC1200 Wi-Fi adapters (alongside the AIO’s Ethernet).
Extra RF/SDR: YARD Stick One.
USB Management: Small additional internal USB hub to route all the extra peripherals.
The Porcupine Array: 15 antennas in total, 14 connected (Comet BNC-W100RX for SDR and Diamond RH789 for YARD Stick One)
Motherboard & Power Mods
Running this much hardware off a uConsole requires a lot of juice and bus stability. Aside from the custom battery pack, I had to make a few board-level modifications:
USB Power Mod: Changed a resistor to bigger one R/6.8 k on the AIO V2 so the USB bus actually gets the full 2A it needs to run all the peripherals.
USB Stability Mod: Swapped out C513 with a 220uF tantalum capacitor on the motherboard for a larger one to keep the USB connection stable under heavy load.
Hard Shutoff Mod: Modded the motherboard so that holding the power button longer switches the console fully off.
Battery Life
Despite the heavy hardware load, that massive 10-cell LG pack delivers:
17 hours with everything idle.
10 hours of continuous SDR running
Software Installed — Full List
It’s running Parrot OS with a massive suite of tools to take advantage of the hardware.
SDR / Radio Reception & Decoding:
GQRX, CubicSDR, SDR++ (Brown), OpenWebRX (Docker)
GNU Radio (packaged) + GNU Radio 3.10.12.0 & VOLK (both built from source)
gr-osmosdr, SoapySDR + device modules (HackRF, RTL-SDR, BladeRF, LimeSDR, Airspy, etc.)
CSDR, inspectrum, multimon-ng, URH (Universal Radio Hacker)
Ham/Digital: WSJT-X, fldigi, flmsg, flamp, QSSTV, DSD-FME, m17-cxx-demod, Dire Wolf, op25 (gr-op25 + gr-op25_repeater), osmo-tetra, telive
Aviation/Sat: gr-satellites, SatDump, Gpredict, JAERO (with JFFT, libcorrect, libacars, qmqtt, mbelib, libaeroambe), acarsdec, readsb, tar1090
Other Tools: welle.io, Xastir, SDRTrunk, kalibrate-hackrf, rx_tools, QSpectrumAnalyzer, gr-lora_sdr, gr-tempest, gps-sdr-sim, UHD, RfCat
(In progress/attempted: falcon, srsRAN Project, OpenAirInterface)
Bluetooth / Wireless:
- Ubertooth, Blueman, mdk3
Networking / Communication:
- Wireshark, Scapy, Signal Desktop, iNTERCEPT (smittix/intercept)
Penetration Testing / Security:
- GEF, XSStrike, SSTImap, Atomic-Operator, Fluxion, AdaptixC2, WPProbe, MetasploitMCP
System Utilities & Browsers:
- partclone, raspi-config, pinctrl, Chromium
STL files: https://drive.google.com/file/d/1TKFaZTDABOls-2Vjvvl8-2hlUcKSup7i/view?usp=sharing
