Adding LTE to internal port on AIOv2
Hello all,
I just got my uconsole built with a cm5 and the AIOv2 from hacker gadgets installed. It all works great, but was looking into options to add cellular connectivity back to the system while keeping the AIOv2. My plan was to source a LTE module like this and make an adapter to plug it in to the internal usb-c port on the AIOv2. However based on the post from hacker gadgets, where they had a bad resistor value on a batch of AIOv2 boards, it seems the AIOv2 is configured for 1.58A max draw on that port and the LTE board seems to need 3.0A peak draw at times. So it seems this would not work cleanly, and may need a higher current source from elsewhere on the board. Any ideas on a good source for that? I was looking at this post where it looks like someone managed to do it but are using an AIOv1 and are routing it via a ribbon cable elswhere. Also cannot tell what LTE board they are using, maybe there is a lower power LTE option out there vs. the one I found I don’t know.
我之前使用的EC20 usb dongle模块,最近也担心电流要求大,功耗高的问题,我已经重新购买了Cat 1的EC801E-CN模块,安装后免驱动,速度还是能接受,大约5mb/s。所以我暂时不用EC20了。
AIOv2和v1的供电情况应该差不多,担心电流要求高,Cat 1也不错
不知道为什么测不出上传速度
Very Cool! Yeah I was concerned about current draw as well. So far I haven’t had any issues, but I just got it built. I’ll do some tests around town, and see if it has any problems or has to reset the LTE board or anything. If I have issues though it seems your solution is the best plan.
我简单测试了一下EC801E-CN的功耗大约在1w左右,EC20我还没测试
