Advice on image for Audio work and mame Emulations boot from nvme
Hi all totally new here and finally getting a cm5 16/16 non lite uconsole used aswell as trying to build a windows version next to it as i am not sure the cm5 has the beef i need for demanding mame emulations (music OS Roms).
So i wanted to ask for a few start up hints. Google says best image for audio is Bookworm? I see trixie is supposed to be more updated.
since the uconsole comes with nvme i want to boot from that. Do i need to modify the image i flash to an sd card for installation with any prompts or similar?
I am also intersted in trying 100hz and not sure if this should be added before or after image flashing. Very much a linux neewb i am afraid
trixie and bookworm are both debian versions and trixie is the most recent one, all of rex’s images use the same kernels so the only real differences between the images is the preinstalled software
trixie probably has the fewest issues compared to the other ones
Thanks thats a start
Do i need to mess with bootloader or eprom and if so where to read how?
if you want to boot from nvme you need to change the boot order in eeprom, and to reliably boot from sdcard on a cm5 you also need to edit the eeprom
he will have non lite version so his sdcard won’t work and won’t need to struggle with eeprom update (but will have to change the boot order)
what is it? if you mean music trackers, there is a post: uConsole Music Production
cm5 is very beefy, most probably you won’t have any issues.
oh yes I missed that part
emmc cm5s can’t use SD card slot at all
the emmc is connected to the same interface the sd card uses so it’s one or the other.
Andy simple guide on the boot order? Is that part of the image flashing or do i need to „mess“ with the eeprom (again no clue how).
I am going for omd samplers like cmi2x and vintage emulation studio. They are mame based and have a hard time even on a new intel chip so i am not sure cm5 will do that
Just flash the image to the nvme and boot, nothing else to do.
I will just this to ask a few more neewb things.
  1. any chance for the trackpad to work on the original keyboard too? I have 2 and 2 keyboards but just one 2.1
  2. any good use for the 16gb emmc, too small for OS while having data/apps on nvme?
  3. Can the sdr signals be used in audio applications, like is the uconsole with the antenna addon (not aio) capable to listen/play subsonic frequencies?
  4. there is no way to use a hdmi oled right?
I don’t believe so as the Trackpad requires the additional ribbon cable connection that the OEM keyboard has no input for.
How much RAM? The only downside of eemc, for me at least, is that on the CM5 it disables SD card usage, which is more versatile than NVMe since you can easily swap between distros.
I use a CM5 lite (no emmc) with NVMe as my main OS, then either a 64Gb or 128Gb SD for other Distros.
If I had an emmc version (ideally 64gb or 128gb), I would just use my favorite Distro with NVMe as additional storage
Not sure what you mean on this? The CM5 does not have SDR, and the uConsole by itself does not bring SDR either, but the AIO does, both v1 & v2.
But yes, I can listen to FM radio for example, I think that answers your queston?
You can connect to an external HDMI OLED display with a Micro HDMI adapter.
If you are referring to the built-in display, you would need to find a display compatible with the uConsole. I believe someone has done it or was looking into it either here or on reddit.
For me, the display is small and good enough that I would rather take the power savings of 720p haha I have other devices for media consumption, plus I would want one of my larger devices for anything requiring detail, etc.
Only 16gig emmc thats why i am asking if that could fit.
I have a 5inch amoled that kinda fits. Its not higher res not sure if i draws more current.
Sdr via the multi antenna adapter
i use a internal usb pendrive for storage data and apps, boot the emmc its work but you cant boot from usb be cause the moderboard boot, but you can swap almost in the usb, the problem its have very low data transfer, if you have the nvme addon can boot directly even in speed 2 are very fast and stable on low batt i reconmend this solution
with HG extra boards you can achieve usb 3 speeds for usb sticks
yes but external, internal usb, i didint rearch usb3 speed it, and i conect internal usb cables, i think maybe had electronic power problem, i cant run the wifi 1200 plus bluetooth at same time, ill ad some capacitors and try but i didint have time to tinker, when i recived the 21700 nvme addon ill try put internal usb hub ad a few caps cheer me luck XD
The multi-antenna adapter won’t do you much good without the AIO board to plug the antennas into and process the signals.
Did not know, bought 2nd hand
Just recieved, flashed trixie to nvme and booted up all super smooth, wifi (well yk…) works sound works, all trouble free. It has actually aio v2, i wasnt aware.
Thanks @Rex for all the work in the images!
Now i know why the trackball and wifi reach hate lol. Someone posted a nice small antenna for better wifi but i can not see the link as aliexpress us only. Someone knows similar in europe? Also should i use the aio extension port somehow, or is that used (with antenna) anyway?
For wifi, do you have the wifi antenna connected to the compute module and not the mainboard?
The sticker antenna is usable if you don’t put it too close to the metal case, a spacer with some double sided foam tape or a 3d print between the antenna and the case helps a lot for signal.
You can use any small wifi antenna as a second option, but it’s hard to recommend something without knowing what you already have laying around as uconsole accesoires.
So i am running my first application an audio sampler/sequencer OS Emu based on mame build for linux.
it runs but stutters and crackles quite a bit and i wonder if there are ways to maximize performance for an application within trixie OS?
Its not that usable as is
