I was in the same situation, accidentally inserted my battery in reverse and killed AXP2101. I replaced it with the one I bought on aliexpress, but my LCD was not comming up after this replacement. Then I found this thread and thanks to the dump of orginal values of the stock AXP registers provided by @cathiele I was able to fix it. I used @JackCarterSmith rewrite of the picocalc BIOS described here:
GIT:
What I basically did is:
modified Src/axp2101.c file and added:
#define AXPI2C_RETRIES 3
#define AXPI2C_TIMEOUT_MS 100
typedef struct {
uint8_t reg;
uint8_t val;
} reg_pair_t;
static const reg_pair_t axp_init[] = {
{0x12,0x00},
{0x22,0x04},
{0x24,0x00},
{0x25,0x19},
{0x27,0x16},
{0x58,0x00},
{0x50,0x12},
{0x62,0x13},
{0x69,0x01},
{0x80,0x01},
{0x82,0x12},
{0x83,0x00},
{0x84,0x00},
{0x85,0x00},
{0x90,0x3F},
{0x91,0x00},
{0x92,0x1C},
{0x93,0x1C},
{0x94,0x1C},
{0x95,0x1C},
{0x96,0x1E},
{0x97,0x1E},
{0x98,0x00},
{0x99,0x00},
{0x9A,0x00},
static HAL_StatusTypeDef axp2101_write_reg(uint8_t reg, uint8_t val)
HAL_StatusTypeDef ret;
for (int attempt = 0; attempt < AXPI2C_RETRIES; ++attempt) {
ret = HAL_I2C_Mem_Write(&hi2c2, AXP2101_DEV_I2C_ID, reg, I2C_MEMADD_SIZE_8BIT, &val, 1, AXPI2C_TIMEOUT_MS);
if (ret == HAL_OK) return HAL_OK;
HAL_Delay(5);
return ret;
int axp2101_init_regs(void)
size_t n = sizeof(axp_init)/sizeof(axp_init[0]);
for (size_t i = 0; i < n; ++i) {
HAL_StatusTypeDef s = axp2101_write_reg(axp_init[i].reg, axp_init[i].val);
if (s != HAL_OK) {
// TODO: error handle
return -1;
return 0;
modified Inc/axp2101.h and added function declaration:
int axp2101_init_regs(void);
and then modified main.c file and added the following after AXP initialization in main() (after line 195)
if (axp2101_init_regs() != 0) {
// TODO: error handling
and BUM, it works! Maybe this will help you as well.
