CM5 Lite, Hacker Gadgets AIO v2, NVMe, Parrot OS – Experience
I came across the uConsole last month and decided that I “need” one in my life. After watching some YouTube Videos, I decided to go full autistic-mode and to implement the latest and greatest upgrades from the get-go.
Ended up with a CM5 Lite 8GB, the complete Hacker Gadgets upgrades and Parrot OS on NVMe. There is an in-depth article with the hole build list on my website – in case somebody wants all the details.
It took me a few days to configure all the aps and get everything going, but for now, the console runs relatively ok. Booting from NVMe works fine and Parrot OS runs basically reliabele. I wanted to have Trixie OS on the microSD and configure it more towards casual gaming, maybe running Doom, but for some reason the uConsole doesn’t seem to like booting from microSD card.
There seems to be some issue with the right timing when booting from sd card, since I can see the OS booting when I connect the uConsole to an external monitor. That is the only problem that I encountered so far, that I still have to solve, yet…
I´ll post my future experience in this thread, so people can laugh about my obvious mistakes and/or leave some constructive feedback
booting from the sd card has some problems, have you followed this guide yet? it will make booting from the sd reliable.
since you are using parrotos fine you probably know you need a custom image to work on the uconsole. you can find my images for the uconsole here.
make sure to download a uconsole image and not one for another device.
you are true to your name! what an ability to find an uconsole unit in a month!
Can the aio v2 expansion be used without the 5v ribbon cable that comes along with it ? I’ve just got mine and I was confused about this because I haven’t bought the upgraded adapter board
The ribbon cable is needed to get usb3.0 speeds, without it all usb ports are limited to USB2.0 speeds.
Without the adapter board the ethernet port won’t work either
Yeah I just read somewhere that without it you can’t charge the Uconsole as it can damage the adapter board. Might as well buy the upgraded adapter board. Thanks for the clarification
Where did you read that?
As far as I know the issue is that the ribbon cable can be inserted the wrong way around and that can damage the board
Read it somewhere before.
oh okay, makes sense
Thanks for the tip! I watched dozens of hours of YouTube videos before even ordering. And I used the shipping time for reading as many Forum posts as possible – especially yours.
I got both, Trixie and Parrot directly from your website and they are both running just fine! Thanks for all the work and dedication you are putting in this project by the way!
After a few days of madly yelling with some AI about the SD card boot problem, I got even that to work – and maybe found one underlining problem as well. I´ll write a detailed article about it and I´m curious if you´ll be able to reproduce the solution I found.
After installing Freedoom on Trixie though, I unfortunately got a little bit carried away with some excessive eehhmmm OS “stress testing” …
I´ve read about all the shipping problems when ordering via ClockworkPI and got it straight from a certified distributor. Got it actually within a week, the prior three weeks were more documenting on the matter than actual waiting. Had to order the AC1200 separately, since it wasn’t in stock on the distributor website. But I got that over Alibaba in about 2 weeks. So, I guess I can´t complain :sweat_smile:
Does your bluetooth work? I’ve got pretty much the same setup as you but ported omarchy to run on the cm5 lite and can get the bluetooth detecting devices but am unable to get them to handshake. I’m starting to wonder if I got a defective AC1200.
bluetooth implementation in linux is a shite. highly recommend to try bluetoothctl, and check logs via journalctl --unit=bluetooth. do not forget to maniacally restart BT service.
My Bluetooth works actually how it should. I´m using the build-in Bluetooth adapter for normal stuff though – like connecting an external keyboard or mouse.
I just tried connecting my Phone with the Console via the AC1200 adapter and it worked as well – I got the Password Popup on both devices. It´s fairly easy with the “Blueman” Bluetooth Manager over the GUI. I have no experience with omarchy, but it´s a very slick OS, as I understand.
After assembling the uConsole and connecting all the hacker gadgets parts, I verified the functionality in Trixie OS. It was annoying and time consuming, but it made trouble shooting in Parrot OS way easier, since I have prior confirmed the basic hardware funcions.
