Custom D.E.O.T. V2.0+/Clockwork OS v0.5 image - With customised DEOT interface, Kernel 5.7, Optional 1400MHz OC, Debian 10 Buster, Retroarch 1.9.0, Mupen64+ plus more! (Current build: 200903)
Update to resolve the above issues, and a few more changes.
DEOT v2+ Build 200323
23th of March 2020
Current changes:
  1. Resolved screen flicker issue.
  2. Provided updated kernel options.
  3. Changed sources.list to use a standardised location (Index of /debian) pointing to buster.
  4. Performed an apt-get upgrade.
  5. Replaced UI elements to allow DEOT Fonts.
  6. Restored DEOT Style Brightness and Sound volume settings pages.
  7. Removed Launcher Go settings page, and removed Launcher Go.
  8. Removed OP-1 and Canis Minor themes. (for now)
  9. Cleaned up Games directories, and moved DEOT Extras folder closer to utilities.
  10. Moved the xbindkeys scripts to their respective directories.
  11. u-boot-tools and flex installed for self kernel compiling.
More info
Flickering problem resolved. (Hopefully?) I have no way of testing if it’s fixed. If someone could report back regarding it, that would be great.
I’ve included a kernel option to change to 5.3.6. This is the stock kernel included with Clockwork OS 0.5. This will now be the default kernel upon booting up. This is the one that should solve your screen flickering issues.
Since 5.3.6 is @shell’s work, I have also provided 5.4.24 (replacing 5.4.21), which is the progression from their original work.
To avoid problems, I’ve removed the 5.5.90 kernel.
Get the updated utilities here:
08_Kernel.zip - Google Drive
(delete the existing 08_Kernel directory, and give the executable bit to the bash scripts as needed.)
Updated sources.list. The stock tsinghua tuna one doesn’t seem to work anymore. I think I just happened to be trying to use it during maintenance. (Archive-Update-in-Progress-nanomirrors.tuna.tsinghua.edu.cn)
Here is what I changed it to.
deb http://deb.debian.org/debian buster main contrib non-free
deb-src http://deb.debian.org/debian buster main contrib non-free
deb http://deb.debian.org/debian-security/ buster/updates main contrib non-free
deb-src http://deb.debian.org/debian-security/ buster/updates main contrib non-free
deb http://deb.debian.org/debian buster-updates main contrib non-free
deb-src http://deb.debian.org/debian buster-updates main contrib non-free
deb http://deb.debian.org/debian buster-backports main contrib non-free
deb-src http://deb.debian.org/debian buster-backports main contrib non-free
Performed an apt-get upgrade. Checked to make sure graphics drivers are functioning correctly.
Replaced UI elements: scroller.py, skin_manager.py, slider.py with stock DEOT versions.
Replaced Settings menu items: Brightness, Sound with stock DEOT versions, removed Launcher Go list item, and replaced modified list_page.py commenting out Launcher Go. Launcher Go also removed from home directory.
Unfortunately, the OP-1 and Canis Minor themes no longer behave due to the above changes. That’s something I’ll work on for the next update. For now, just use the DEOT theme.
Removed strangely redundant games directories. Eg, the old MAME, MGBA, PCSX etc. They have since changed to ARCADE, GBA, PSX to reflect the console name, as opposed to the emulator name. This was done a while ago, so I have no idea why or how they came back. Also, moved the DEOT Extras directory to be next to the Utils, since it made more sense to have the games together.
Moved the xbindkeys scripts to their respective directories. Just for the sake of cleaning up the user home directory. This applies to Samplerbox and SCUMMVM.
u-boot-tools and flex have been left installed, in case you want to compile your own kernels, and admittedly, so I don’t have to keep reinstalling it every time I flash a new card.
As usual, the links will be uploaded in a few hours to my google drive, then I’ll upload it to mega. When I have a bit of time, I’ll also make a zeroed empty space and auto expanding image.
