DragonOS 7.1.y for the uConsole and DevTerm
hi again i bought the cm5 but accidentaly bought non lite and i found that if you remove the smd chip that identifies how many gb emmc it will recognize it as lite is that true?
why not just make use of the emmc?
Hi All,
I am having issues getting DragonOS or any other OS booting on the uconsole with CM5 lite. At first I was able to boot trixie and then later had success with booting DragonOS. However after shutting down the uconsole it won’t boot anymore, I get a blank screen. I have tried reflashing several time and with different sd cards with no success. When plugging a monitor to the uconsole i get the following. I did not get a chance to update the eeprom. Any ideas why all of a sudden it stopped booting? I am running out of ideas on trouble shooting.
Any help is much appreciated. Thanks so much
Solved now, managed to get an sd card working and updated the eeprom as per the instructions from @Rex found in similar posts. Now it seems to be booting normally. Thanks
Have tried to download the DragonOS twice but when I try to write it to a sd card using balena etcher I keep getting an error message.
Try using raspberry pi images without any custom settings.
try unzip, then write it
