I successfully flashed the eeprom to boot 0xf46 but I still get no response from the display, I plugged in an HDMI monitor and was able to capture this info. It seems like it’s only seeing the eMMC disk though. I flashed the NVME with Rex’s Kali version. But no luck yet. (hackerGadgets CM5 adapter board + NVMe battery board upgrade )
The “VCHI initialization failed” error on a Raspberry Pi typically occurs when the user does not have the necessary permissions to access the VideoCore hardware. To fix this, you need to add your user to the “video” group using the command sudo usermod -G video your_username and then restart your system or the relevant service.
Thanks, but.. This was already solved months ago, and there is no spacer used
Its just a CM5 with the official adapter and official mainboard. At least it was at that time
I am using a CM5, without a spacer. I do NOT have any heat issues, I do however have a heat skink and fan that I will be installing once I get a new back plate printed.
Maybe its the SD card or I’m doing something wrong..
I’ve done the EEPROM update as linked by Rex and saved the config: It looks like the config isn’t saved.
I can only boot up images freshly written wit TwisterOS, Trixie and DragonOs (others don’t work) and after reboot I get kernel panic on the external monitor..
You’re having a different error then one associated with the eeprom. Try putting kernel=kernel8.img in you config.txt in the pi5 section. I noticed building a new Trixie image that the 16k kernel isn’t booting using kernel8 will make the cm5 use the 4k kernel.
For now, I can only boot up DragonOS and have done the eeprom-update & after that used raspi-config when booted.
In raspi-config, I’ve made changes the NVME speed to 2x and reviewed the boot order (SD/USB/NVME/Network) and instead of reboot I did shut down.
Rebooting doesn’t work (hangs/crashes), but shutdown and startup does work now.
I’ve ordered the HG upgrade kit without extension cards (I have the AIO v1) and requested to modify the NVME-battery board with a reset/power switch: That will greatly help the hanging issues without taking batteries out
