# Fan shroud for Devterm
**URL:** <https://forum.clockworkpi.com/t/fan-shroud-for-devterm/7598>\
**Category:** DevTerm\
**Tags:** tinkering, community, hardware\
**Created:** [December 9, 2021, 10:22am UTC](https://forum.clockworkpi.com/t/fan-shroud-for-devterm/7598 "2021-12-09T10:22:47Z")\
**Showing post:** 17
**Author:** ![adcockm](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/adcockm/32/1664_2.png) [@adcockm](https://forum.clockworkpi.com/u/adcockm)\
**Post date:** [December 9, 2021, 11:52pm UTC](https://forum.clockworkpi.com/t/fan-shroud-for-devterm/7598/17 "2021-12-09T23:52:15Z")
I’d be curious to see how this compares to the default adhesive on the heatsink. Maybe if someone else does this they can run a test with numbers, like the stuff posted here:
> [@Dolphin GameCube/Wii Emulation and the Devterm A06](https://forum.clockworkpi.com/t/dolphin-gamecube-wii-emulation-and-the-devterm-a06/7572/11):
> I guarantee it is. It’s less than 20°C in the office right now, and mine throttles under sustained load on gear six - so if it’s 40°C where you are, you’re going to hit that limit that much sooner! Easy way to find out is to run the following in a terminal next to your emulator (or output it to a file for later review if you’re running the emulator full-screen): watch cat /sys/class/thermal/thermal\_zone0/temp /sys/devices/system/cpu/cpu\*/cpufreq/cpuinfo\_cur\_freq The first number it prints ou…
Given time I might even end up doing it myself and posting something. But I haven’t taken the time to actually build my devterm yet, so first things first! 🙂
_[View the full topic](https://forum.clockworkpi.com/t/fan-shroud-for-devterm/7598)._
