# Fixing uConsole power delivery limitations with CM5
**URL:** <https://forum.clockworkpi.com/t/fixing-uconsole-power-delivery-limitations-with-cm5/19119>\
**Category:** uConsole\
**Created:** [August 10, 2025, 6:05pm UTC](https://forum.clockworkpi.com/t/fixing-uconsole-power-delivery-limitations-with-cm5/19119 "2025-08-10T18:05:41Z")\
**Showing post:** 7
**Author:** ![neocska92](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/neocska92/32/10052_2.png) [@neocska92](https://forum.clockworkpi.com/u/neocska92)\
**Post date:** [August 14, 2025, 12:15pm UTC](https://forum.clockworkpi.com/t/fixing-uconsole-power-delivery-limitations-with-cm5/19119/7 "2025-08-14T12:15:27Z")
> [@hotellonely](#):
> It only happens on CM5, and it happens regardless of muted or not. Only happens when battery level is low.
First of all, CM5 is power-hungry.it needs 5Amps, I recommend to downclock a little bit.
You can use better quality cells 18650 with higher discharge current rating. 10A+. I have sony(murata) vtc5A cells in my uconsole with cm5 board, and for what i use I cant reproduce this problem.
_[View the full topic](https://forum.clockworkpi.com/t/fixing-uconsole-power-delivery-limitations-with-cm5/19119)._
