yes I tried but they are same
Did you use the aiov2_ctl.py script to make sure to turn on the devices?
no i m not understand how to use it.there is not doc for this board so i m handless.
bored99 <notifications@clockworkpi.discoursemail.com>于2026年1月10日 周六下午11:07写道:
can u tell me how to use it and where is this script?thx
Blaze Hu <blazehu314@gmail.com>于2026年1月10日 周六下午11:11写道:
check it out here.
Howdy, Just installed Trixie with the new AIO 2 goodies w/NVME. Install went fine. OS up and running. Youtube with audio just fine. Added Rex’a Hacker Gadgets AIO package using script above. SDR++ came with up, tunes and receives fine. No audio though. I followed:
“If you’re using Trixie you’ll need to add an audio sink. On the left side scroll down to Module Manager. At the bottom of Module Manager type audio and select linux_pulseaudio_sinkthen click the + symbol. Then add the audio sink in the Sinks menu on the left side back up towards the top.“
I select “linux_pulseaudio_sink“ theb try to click the “+” symbol and nothing happens. No “audio sink” appears in the “Sinks” menu. Any suggestions? Thx.
Did you name the sink?
Not sure what you mean, I followed the instruction. A little unclear on “type audio”
Got it now! Actually typed audio into the empty box. Works now. On another note, PyGPSClient, unable to get it to work after selection /dev/ttyAMA0. The box shows n/a next to the selection. Thx
There’s a place to name the audio sink and then pick the device that newly name sink goes to.
Got it now thanks!
On another note, unable to get PyGPSClient to work after selection /dev/ttyAMA0. The box shows n/a next to the selection. The device is shown in terminal when I ls -l /dev/ttyAMA*.
if you are on the AIOv2 board, make sure you have turned on the GPS chip using the aiov2_ctl.py script.
Hi, I have a huge problem. I installed my AIO2 board, but it doesn’t seem to be recognized at all. None of the installed programs are running. Everything is installed as described in the first post. The only thing is that both LEDs on the RJ45 port are constantly lit. I don’t need the RJ45 port. It’s not supported even without the new adapter board, which I haven’t installed. I used a freshly installed image from Bookworm and Trixie for this. Does anyone have any ideas?
the AIOv2 is different from the V1 and requires an additional script to turn everything on
Thank you for the link. I’ll test it. Vileer expanded the description this morning. Unfortunately, I’m a complete noob when it comes to Linux…
Absolutely — here’s a clean, durable summary you (and others) can follow to reach a known-good RTL-SDR operating point on ClockworkPi 132 with AIO V2 + SDR++ Brown.
KNOWN-GOOD OPERATING SEQUENCE (IMPORTANT)
Order matters. Always do this in order:
- Turn SDR power ON (AIO V2)
cd ~/aiov2_ctl
python3 aiov2_ctl.py SDR on
- Then start SDR++ Brown from the local desktop
Do not start SDR++ before SDR power is enabled
Do not start from plain SSH (no DISPLAY)
BEST INITIAL SDR++ SETTINGS (FM Broadcast – proven)
Source (RTL-SDR)
Driver:
RTL-SDR (Native / Soapy RTL) -
Frequency:
101.900000 MHz -
Sample Rate:
2.048 MSPS -
Gain:
Auto(or Manual ~25–35 dB) -
Direct Sampling: OFF
Demodulator
Mode:
WFM -
Bandwidth: 200 kHz
(critical) -
De-emphasis: 75 µs (US standard)
Stereo: OFF initially (enable later if signal is strong)
Audio
Audio Rate:
48,000 Hz -
AGC: OFF
Noise Reduction: OFF
Squelch: OFF
Waterfall / Zoom
Zoom so the FM signal fills ~180–200 kHz
Too wide = distortion
Too narrow = noisy / thin audio
WHY THIS WORKS
These settings match exactly what this proven CLI command does:
rtl_fm -f 101.9M -M wbfm -s 200k -r 48k - | aplay -r 48000 -f S16_LE
Anything that deviates (bandwidth, AGC, stereo, DSP) causes:
choppy audio
static
CPU overruns
SDR++ instability
ONE-PROGRAM-AT-A-TIME RULE
The RTL-SDR cannot be shared unless using rtl_tcp.
SDR++ Play ON → CLI tools will FAIL
rtl_fmrunning → SDR++ will FAIL
Always stop one before starting the other.
CRITICAL DIAGNOSTIC COMMANDS (KEEP THESE)
Is the SDR physically present?
lsusb | grep -i 2838
Is the kernel stealing it as DVB? (bad)
dmesg -T | egrep -i "dvb|rtl283|rtl28xx"
If yes → blacklist required.
Blacklist DVB drivers (one-time fix)
sudo tee /etc/modprobe.d/rtl-sdr-blacklist.conf >/dev/null <<'EOF'
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
blacklist rtl2830
blacklist rtl2832_sdr
EOF
Is something already using the SDR?
sudo fuser -v /dev/bus/usb/001/008
If you see:
readsb -
dump1090 -
rtl_*
→ they must be stopped.
Stop ADS-B service (common blocker)
sudo systemctl stop readsb
sudo systemctl disable readsb
Can librtlsdr open the device? (gold test)
rtl_test -t
Should list device and tuner with no usb_claim_interface error
COMMON FAILURE CAUSES (WHAT WE HIT)
| Symptom | Root Cause |
| Device shows but no waterfall | DVB driver attached |
usb_claim_interface error -6 |
Another program owns SDR |
| SDR++ crashes from SSH | No DISPLAY (GUI app) |
| Static / choppy FM | Wrong bandwidth, AGC, stereo |
| SDR++ won’t start | SDR power not enabled first |
and for manually tuning 101.9 FM on SDR++ Brown on Clockworkpi
Your SSH command is giving clean audio because it is very specific about bandwidth, demodulation, and filtering. SDR++ defaults are not equivalent, which causes the choppy/static sound.
Set only these settings in SDR++:
Source (RTL-SDR)
Frequency:
101.900000 MHz -
Sample Rate: 2.048 MSPS
Gain: Auto (for now)
Radio / Demodulator
Mode: WFM (Wide FM)
WFM Bandwidth: 200 kHz ← critical
De-emphasis: 75 µs (US FM standard)
Stereo: OFF (turn ON later if signal is strong)
rtl_fm -M wbfm -s 200k
this is why 200 kHz matters
Audio
Audio Sample Rate: 48,000 Hz
Audio Output: Default (same device
aplayuses) -
Audio Buffer: leave default
DSP / Filtering
Squelch: OFF
AGC: OFF (important — rtl_fm does its own leveling)
Zoom / Waterfall
Zoom in so the FM signal fully fills ~180–200 kHz
If the signal spills wider → distortion
If it’s narrower → audio will sound thin or noisy
I hope this helps others. Great product!
Ed
Cheers for the writeup. Going to see if I can hear CH19 on the CB a little later (I have proper antennas and adapters for that).
Just an FYI that enabling power on the usbc rail does not provide enough power for the Wifi/Bluetooth chip, if you also ordered that.
More info here: HackerGadgets' uConsole Upgrade Kit - adding NVME SSD(PCIe), RJ45 Ethernet and USB 3.0 to your Uconsole - #527 by AceMedia
