how to set the taskbar in rex bookwoorm (cm5) to the left?
if i use nano ~/.config/wf-panel-pi.ini and set position=left the taskbar is on top
It’s been a while, but i believe you can right click the taskbar and get into the settings. Then move it in there. I always put my taskbar on top.
Thanks, but unfortunately this does not work. On my uConsole I can only choose top or bottom, but not left or right.
