I'm stuck, and my frustration is winning
@vileer :snake: :brown_mushroom: :house:
test each piece, first just the adapter, then add the battery board (no nvme installed), then put in a nvme. so forth and so on. till something quits.
Rex gave the correct answer for diagnosing the issue.
can we ban this LLM bot that keeps posting the same message?
Got my replacement board today from hackergadgets, and once again blank screen… brand new board and it STILL wont work…:man_facepalming:
OEM board works just fine tho..
do any warnings or disconnects happen in dmesg at all?
sometimes its really helpful when theres janky hardware.
the bot is back. (20 char)
On the CW board, this is what’s coming up
I can’t get an image on the uconsole with the AIOv2, I’ve literally spent all day today swapping my cm5 back and forth between carrier boards, and editing the boot/config file, while roaming thru every forum for a solution and nothing will work lol. I know it’s not the board itself (shout out HackerGadgets customer service) I got a new board few days ago but no luck..
