# New Hacker Gadgets Dual 21700 Battery Holder
**URL:** <https://forum.clockworkpi.com/t/new-hacker-gadgets-dual-21700-battery-holder/23216>\
**Category:** uConsole\
**Tags:** hardware\
**Created:** [August 24, 2026, 11:42pm UTC](https://forum.clockworkpi.com/t/new-hacker-gadgets-dual-21700-battery-holder/23216 "2026-08-24T23:42:08Z")\
**Showing post:** 54
**Author:** ![white-round-square](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/white-round-square/32/10385_2.png) [@white-round-square](https://forum.clockworkpi.com/u/white-round-square)\
**Post date:** [October 3, 2026, 9:13pm UTC](https://forum.clockworkpi.com/t/new-hacker-gadgets-dual-21700-battery-holder/23216/54 "2026-10-03T21:13:36Z")
> [@deathg0d](#):
> I did the battery calibration steps but the battery always just stop at 82% and never go pass this.
can you please check if you’ve hardcoded values there?
> [@Good runtime, but inaccurate charge level indicator despite calibration](https://forum.clockworkpi.com/t/good-runtime-but-inaccurate-charge-level-indicator-despite-calibration/22410/10):
> I had a lot of trouble trusting the battery monitor on Trixie. Even after calibration, it was frequently inaccurate, and I often had to physically remove and reinsert the batteries just to reset the counters. Even then, the readings were unpredictable. Since my workload is relatively heavy (mostly SDR usage), the system would sometimes simply power off around 30% battery remaining, likely due to a mix of temperature, current draw, voltage sag under load, and similar factors. Because of this, I…
_[View the full topic](https://forum.clockworkpi.com/t/new-hacker-gadgets-dual-21700-battery-holder/23216)._
