New Hacker Gadgets Dual 21700 Battery Holder
:face_with_peeking_eye: How did that happen? Was it a short circuit? How hot is your uConsole running? Keep in mind, that tape doesn’t melt easily.
That’s really strange. I’m going to measure that capacitor’s temperature with an infrared thermometer. I put the tape on it, and it still looks exactly the same as when I applied it. It doesn’t seem to have gotten that hot. When I swap the batteries again, I’ll check the temperature.
when the battery voltage drops to below 3.3v, the screen does indeed blackout, but the system is still running, everything is running except the PMIC and blacklight, even the display itself is okay too, You can still use the uconsole via ssh or vnc. After I manully set the battery capacity down to 36wh, the issue is still there, and the system can still running hours long after the pmic and blacklight die. Here is the last sight the system before shutdown, you can see the pmic didn’t show anything due to the early cut off of the i2c bus.
I will try to set the low_voltatge of the pmic to 3300000, and I’ll post the result later.
Take a look at my screenshot — that’s an SSH connection too. What I found really strange is that your PCI bus isn’t exposing the sensor. The display has shut off; it’s not in standby. Does this also happen when you plug it into external power?
The fact that it shuts off suggests something else. Maybe a setting or a routine is turning the screen off completely, since the sensor isn’t even showing up anymore. I’d review those settings.
One more thing: try updating your kernel — yours is quite old. Try 7.1.4-v8-16k+; that version works very well. From your screenshot, it looks like you’re running 6.12-92-v8+, and I suspect updating the kernel alone might resolve this issue.
My2cents.
I’ve used many AI tools to login the device and look around with the sechmatic of the axp20x pmic, they all suggested that the power of backlight and pmic internal digital logic are on the ldo rail from the battery directly, and the reason why they are cut out is low battery voltage, but the cm5 is on the dc-dc rail, so the cm5 itself is running well. This mean that uconsle only can run on voltage above 3.3v, and this is a bad news, since when the uconsle safely shutdown, there will always be some energy left in the battery.
I will upgrade the kernel then do some test.
I had something similar done on my uconsole.
I really do think voltage could be the issue. I’ve tested batteries with different discharge current ratings and seen the same thing happen. Still, I’d apply Occam’s razor and upgrade the kernel and see save energy parameters, including the drivers, to rule out a software issue first. Remember, the script saves logs, so you can use those to check for low voltage when the screen goes black. If that turns out to be the cause, I’d try batteries with a higher discharge current rating and see whether that helps.
You’ve got me curious! I’ll run the same tests here and use the logs to pinpoint exactly when the screen goes black. I’d never paid close attention to whether the screen actually loses power, and low voltage hadn’t crossed my mind, but I’ll check the logs. You’re in luck: I was too lazy to put the EVE batteries back in, so I still have the other ones installed! :grin:
This could be an interesting finding, and I’d really like to understand what’s happening. I’ll do the tests.
Well, here’s my conclusion: from now on, I’m sticking to cells with a discharge rating of at least 30 A in my uConsole. I tested these two models:
Blue : EVE INR21700-40PL
Gray: LG INR21700-M50T
The same thing happened again: with the LG INR21700-M50T cells, the uConsole abruptly shut down at 23% battery remaining, with a reported voltage of 3.23 V. Puff…goindown. :enraged_face:
With the EVE cells, I can get down to 1% without that shutdown. For my setup and workload, this strongly suggests that the cells’ ability to deliver current and maintain voltage under load makes a practical difference.
I understand that the power-management chip and other components have their own limits. A higher discharge rating doesn’t mean the uConsole will draw 30 A; it simply gives the cells more current-delivery headroom. These tests don’t establish 30 A as a universal requirement or prove the exact cause, but they’re enough for me to make a practical choice: I’m going back to the EVEs and prioritizing stability over extra capacity.
This is my experience with my hardware and workload, so it won’t necessarily apply to everyone. If anyone would like the logs, feel free to send me a private message.
Note: See the Throttle Status! 0x80000. Heat! As I’ve said several times already, yes, this affects the current and my system was running at 40°C! :face_with_monocle:
I may have the same conclusion, I switched to 2x Samsung 50s battery,and it seems to shutdown when the gauge down to 0, and still have 3.45v left in the battery. And current rating of the samsung 50s is higher than the EVE 58E. I will do more test.
And by the way, can you share your newest uConsole CM5 HW monitor script? The link you post above seems not avaliable now.
Hey,
What is script for, please?
They’re scripts I write to test things firsthand, mostly to do with power and temperature, but I use them to look at other things too. Actually, I was looking into something else and ended up making a new version with a better interface. If you search the forum, you’ll see I’m pretty obsessed with power and thermals on the uConsole. :grin:
To get the uConsole monitor going, just drop both files in a folder (say ~/monitor), cd into it and make them executable once with chmod +x uconsole_thermal_mon.py uconsole-thermal-mon-v4.2.sh. Run the Python version with ./uconsole_thermal_mon.py or the shell version with ./uconsole-thermal-mon-v4.2.sh. They both show the exact same screen, and if you throw sudo in front you’ll get your SSD’s SMART data too. Once it’s running, hit Tab to flip between the main page and the power & sensors page, p to mark the Peltier on or off, l to turn logging on or off, s to refresh SMART right away, and q to quit. Logs land in the same folder as the script (memory_report.log and power_report.log), with a new line every 5 seconds. Want to check out the screen without a uConsole? Run ./uconsole_thermal_mon.py --demo (that one’s Python-only).
To see your SSD’s health (SMART), you’ll need smartmontools: just run sudo apt install smartmontools. Reading SMART needs root, so start the monitor with sudo, like sudo ./uconsole_thermal_mon.py or sudo ./uconsole-thermal-mon-v4.2.sh. Without it, everything else works fine, but the NVMe SMART panel will just say it can’t read the data.
Download Version 4.2 (Shell and Py)
Enjoy
Note: Sorry, I love terminals! :smiling_face_with_sunglasses:
i try https://es.aliexpress.com/item/1005012770069155.html?spm=a2g0o.order_list.order_list_main.52.5ece194dYXpBk0&gatewayAdapt=glo2esp and at 20% have some crashes but sometimes run to 3% but the standar on are about 2.5 hours of stable work, even the tester say 6500mah testing… im gona try https://es.aliexpress.com/item/1005013235841017.html?spm=a2g0o.order_list.order_list_main.5.5ece194dYXpBk0&gatewayAdapt=glo2esp cheer me luck ill report when arrives
can you explan me please where are the other sensors? rpi adc … etc the main nemve sais ok but my others sensors said too hot
thnaks
I’d recommend using the latest version. It monitors eight temperature channels, and I’ve also been exploring power consumption in this release. The table explains what each channel measures.
A few months ago, I posted a detailed explanation on the forum about why the RP1 is the biggest contributor to heat on the CM5 - The CPU is only one source of heat in the uConsole. Several other components generate heat too, and some can run hotter than the CPU - That’s true of all Raspberry Pi Compute Module 5 units. You should be able to find it by searching for “RP1” on the forum or internet. These are the current readings from my uConsole. Yours may show different values. I can track all of this because the script generates detailed logs. I wrote it for my own use to better understand how my uConsole behaves. I keep improving it as I go, and anyone is welcome to use it for free. It’s a personal project that I share as-is, without support.
thanks maebe you can make a github/gitlab i use one yours old version and modify a little because i dont have any kind of fan or pertier all is just passive cooling, but now i’m testing the batteries and it’s just like teory big capacity low discharge unstable voltage… waiting the 40A 6000mah batteries i hope not being scammed… thanks for the script
The runtime difference you mention is substantial, though I would want to know the exact load and screen brightness before treating those figures as directly comparable. Battery capacity alone rarely tells the whole story, since cell chemistry and discharge curves matter too. You mentioned sticking with 30A cells. Have you checked whether the holder’s contacts and wiring can handle the continuous current without meaningful voltage sag? That seems like the detail worth watching once you run your tests, more than the headline play-time numbers.
That’s why I created this tool: so everyone can measure things the same way. Every uConsole is unique in terms of usage, workload, battery models, and the peripherals connected both internally and externally. I agree with what you’re saying, which is why it’s important to measure your own uConsole under your actual use conditions. All the readings are in the logs, so we can compare the data and understand why the results differ. We’re talking about open hardware here. Using a consistent measurement method and working together to understand the differences between setups is important. Every setup has its own characteristics.
Without comparing actual data, it comes down to opinions and individual impressions based on each user’s experience. Share your logs and compare them—you’ll notice plenty of differences. There’s no right or wrong here; it’s simply about understanding how your device behaves with your setup and the way you use it. And you can be sure the results will never be exactly the same. I’ve written a lot about this already. That’s the magic of open hardware: you built it, and figuring it out is part of the fun.
That’s just my opinion, and how I see this wonderful project called uConsole and the community around it.
Note: I think it’s very unlikely I’d burn out a PCB trace, since the chip has its own limits. I’d expect the chip to fail first, and I believe the wiring and contacts are more than adequate for the current involved. Otherwise, mine would have burned out months ago. That said, I’m very careful about the batteries I buy. I read the specifications and choose carefully to avoid counterfeits. Poor-quality batteries really can fry your uConsole.
I think rechargeable batteries seem to be a matter of faith… :winking_face_with_tongue:
I’d already pointed out in a comment that the device neither requires nor can physically handle this current. If a reputable manufacturer specifies a continuous (!) load of 10 A per cell, that is absolutely sufficient, especially when using two cells. The emphasis here is on a reputable manufacturer.
After all, it is actually the discharge curve that determines the point at which the system switches off, as soon as the voltage falls below the uConsole’s minimum voltage.
