New uConsole boot woes
I recently received my new uConsole from opensourcesdrlab.com. When I boot it, the power button goes on but I can’t reliably get any output to the display or HDMI. Scratching my head on this one.
Here’s what I know.
  • I’m trying to get Rex’s Bookworm image to boot.
  • I have a CM4 lite.
  • Rex’s Bookworm SD card + CM4 boot fine and reliably on a spare RetroFlag GPI Case 2 that I have. No on-screen output there, but I can see it boot fine on the HDMI out.
  • When trying on the uConsole, I’m on USB power, get a green power light, flash on the uConsole screen. Then nothing on either the screen or the HDMI. I’ve waited 5-10 minutes each time
  • When booting from a fresh card it doesn’t look like it’s booting at all - cmdline.txt still has the firstboot line (assuming that’s still a thing with this distro).
  • I’ve reseated the CM4 and carrier board multiple times. Good sounding clicks all around.
  • It randomly booted up (screen and HDMI) once when I had the batteries out of the uConsole. I was able to reboot it reliably multiple times. I thought “aha!”, tested the batteries (both seemed fine - 4.2v), reseated the battery board, reinstalled the batteries… nothing again. Removed them to get back to the bootable state and … now still nothing again. :frowning: I used up all of my luck, apparently.
I don’t see a UART header I can use to see diagnostics… Image of my uConsole attached.
Any thoughts on what to try next? Could I have a bad main board? How would I even test that?
Thanks in advance for any suggestions.
Ryan
Oh, I’ve also tried a couple of different chargers.
after first boot your system should do some tasks and then reboot. people say that if first boot was interrupted – system becomes dead for some reason.
most of boot issues are connected to cm5, with cm4 everything should be smooth.
so I would say try to flash a new trixie image, boot it and wait till auto-reboot. then it should work.
you can throw away that plastic thingy or it will become loose and will do clang-clang inside.
ps – nice troubleshooting list <3
Thanks, good advice. I flashed a Trixie image and tried that one. On the second or third boot, I finally got some boot output. Looks like a kernel panic of some sort. I can’t tell if everything before that point is as expected or not. I used Raspberry Pi Imager to flash this card, and it said it verified it, but in the absence of any other leads, I suppose I could try reflashing it and trying again.
did you flash using custom settings in rpi-imager? if so don’t use any custom settings. also can you try a different sd card if the custom settings thing doesn’t apply.
I did flash is with the Raspberry Pi Imager, and it didn’t offer me custom settings. I flashed a different card, and had the same issue:
  • No output at all on the uConsole. Rebooted ~ 5 times. Switch CM4 and SD card to the GPI2 Case, See boot messages (with same kernel panic) on the HDMI out. No idea why I couldn’t see anything on the uConsole… Then…
  • Swap CM4 and SD card back to the uConsole. On the second power cycle, I see the boot message on HDMI out. Same kernel panic. All reboot/power cycles wait about 10-20 minutes (I was cooking dinner too :).
I did find something (that might be nothing). I peeked at the SD card using:
dd if=/dev/rdisk6s2 bs=1024 skip=1 count=1 | xxd | head -5
and all I see is zeroes. Is that to be expected? I would have thought this partition would have had some data in it… but I am certainly not an expert.
FWIW, I’m using the Trixie image ClockworkPi-Debian-13-Trixie-lite-7.1.4.img.xz from AK-REX - Images.
try to flash image with dd, not a rpi imager?
No, I flashed with rpi imager. After I got the same kernel panic error, was just trying to read the bootfs linux partition to see if anything looked out of sorts there. I’ll try again with the full Trixie image (that one was “lite”), and see if I get the same error again.
This feels like it may be unrelated to the original boot issues.
you sure your not applying any username/password or wifi stuff when flashing using rpi imager? because that is also what happens when you do. try flashing with something else like etcher, dd, usbimager.
Okay, come with me on my wild ride…
Based on Rex’s suggestion, I reflashed my card using dd with the full version of Trixie from his site. Lo and behold, it booted right up. Maybe it took one reboot. I was able to power cycle it, and it would boot again, although for some reason my trackball isn’t working very well. Maybe I’ve installed it wrong, and I couldn’t navigate the full UI.
With my heart full of sunbeams, I decided that must have been the problem. I used DD to flash a new copy of Trixie Lite to avoid having to deal with using the trackball to mouse around a UI. Booted, and … nothing. Black screen and HDMI again. Tried multiple times, with plenty of wait time. Put the exact same full Trixie card back in and… nothing. It didn’t come up at all this time - with 4 or 5 tries.
Flashed a copy of Rex’s Bookworm lite using dd, and … it booted… twice, but no more. The only change was I unplugged and replugged the device.
I’m going to go have a beer and cry gently. :slight_smile:
this is the same issue i was seeing with the lite images, i was able to fix it here: New Images link! - #37 by radcon
the primary partition table is somehow zeroed out on the images but the backup still exists so if you boot into a linux system you can fix the image and reflash
some trackballs work worse than others.
you can try:
  1. qmk keyboard firmware: New QMK Firmware, Trackball Guide and Keyboard Diffuser
  2. EVQWJN007 Trackball Troubleshooting, Fixes and Mods
@radcon Thanks for the pointer. I confirmed the issue, patched the image, and got the uConsole to boot three times. After the third time I moved the device, unplugged and replugged the power cord, and now it won’t boot again. Reflashed with the patched image and still no good. Tried a second new card, and still no good.
I’m beginning to suspect a main board problem. I’ll reach out to opensourcesdrlab.com and see what they want to do.
Any other suggestions are welcome in the meanwhile.
looks like bad contact somewhere, no other ideas tbh.
try to boot it without back cover, but press boards in different places? may be pressure somewhere will point you somewhere…
@white-round-square Thanks for the suggestion.
I swapped the CM4 and card out of the uConsole and into the GPI Case (to make sure it wasn’t a card or CM4 issue again), where they boot fine. Swapped back after disassembling/reassembling the uConsole. It booted on the second or third attempt, but wouldn’t boot after that. I tried applying pressure to various parts as I booted in the uConsole, but that didn’t seem to make a difference.
Hey Ryan, I bought the RPI uConsole CM4 LITE 2 months ago. It arrived without the Compute module, and i thought it was good to go. I flashed the 4 SD cards with the official raspberry pi image and still it couldn’t boot. I also troubleshot the hardwares ,the thing is you can follow all the troubleshooting scripts but it might not work. The only thing you are doing wrong might be flashing the raspberry pi image on the SD card. An AI can help you do it right. Secondly the computer you’re using to flash the image to the SD card might not be setup right to flash the proper image to the SD card. Chat gpt helped me set that up and believe me a wrong laptop setup is more complicated than the whole uConsole booting problem you’re having. After I flashed the RPI image on my final card I just waited for the Compute module I ordered and when it arrived, I just clipped it in place and wallaa the uconsole booted up. Also about the cursor, you have to reduce the size to get it to work properly. I hope this helps
The uConsole needs lots of patience. Keep playing with it, it’s a fun journey you can never get tired. It’s a real hacker gadget. The web extensions allows me to watch videos without interference and download them.
