will do now! appreciate it!
its must be something wrong with the sd slot or the main sodimm
i’ve swithced to a lower capacity sd card and tried balena and raspberry pi imager no cigar
what is your cm4 model number?
it’s definitely a lite model, the emmc chip is the one next to the SOC and the wifi chip and his picture shows no chip there
ok guys, we have progress…
i still haven’t gotten the chance to make sure onboard screen works but i have image on monitor
below are the steps that i did to get this far:
Unplug your microSD card from the Clockwork board and insert it into your computer.
Open the card directory using your computer’s file explorer. You will see a small, readable section labeled boot or bootfs.
Locate the file named
config.txtand open it with a simple text editor (like Notepad on Windows or TextEdit on Mac). -
Scroll all the way down to the very bottom of the file, add this exact line on its own new row:
text
dtoverlay=dwc2,dr_mode=hostUse code with caution.
(If you see any line that says
otg_mode=1, type a#right in front of it to disable it, like this:#otg_mode=1) -
Save the file and properly eject the microSD card from your computer.
thank you to everyone that chimed in!!! i’m sure this wont be the last time i’m at ya’lls mercy!!
still no cigar on internal screen. its not flashing or anything. can only see using external monitor.
you’re using one of rex’s images linked earlier? or the ones from the clockwork github? or normal pi images?
using rex’s Parrot Security 7.3
everything seems to be working but screen on actusl console
can you please try trixie?
that picture of the monitor, that is not parrotos. that’s not even one of my images.
correct, i used your parrot after i found out it worked , i’m going to try your debian trixie now like @white-round-square suggested now
i have now installed " ClockworkPi-Debian-13-Trixie-7.1.4.img.xz " still no on board screen image
Have you tried to reseating the ribbon cable?
yup more times than i can count
Not dead screen? Or new type?
