PicoMite Firmware Version 6.02.00a for use on ClockWorkPi PicoCalc
Your :disguised_face: are better then mine, I did not see that.
The following are hot from Github
08/02/2026  20:46           155.676 PicoCalc_BIOS_factory_v1.4.hex
08/02/2026  20:46            65.536 PicoCalc_BIOS_v1.4.bin
Could this be the hex file with wrong suffix ?
The hex file is ASCII text and has to be sent using a different protocol than the bin file. The bin can just be sent a byte at a time directly while the hex file has to be interpreted as the ASCII text comes in.
My guess is also that at some point the .hex file mistakenly got renamed.
Thanks for your observation and everyone’s patience. Turns out it was related to how I downloaded the file from github. I tried again and made sure the file was the right size and things are now working!
I’m looking forward to being able to move things from PicoMite to PicoCalc with the new language features (structures in particular). Thanks, Ernst for your efforts on this.
Don’t forget the new 6.02 manual…
Thanks for the tips on flashing. I flashed the standard Picocalc with picocalc_v6.02.00a_pico.uf2. Now the data connection with the Maximite Control Center via MM Edit 5.3.3 no longer works. Do I need to do anything else to get it working again? The original came with bootloader V0.5 and MBasic as PicoMite_cbf6d71.bin. When I flashed it back, everything worked again.
I suggest you nuke the pico with flash_nuke.uf2 and then flash the v6.02.00a uf2.
I don’t know anything about MMEdit but I got it to work with no problems using MMEdit 5.4 under Windows and V6.02.00a on the PicoCalc connected through the micro USB.
 To show all toolbars, select 'Show full menus' in Setup menu
A:\untitled.bas
File read failed!!
Nothing to load.
 Connected to COM5 at 115200
option list
PicoMite MMBasic RP2350A V6.02.00
OPTION SYSTEM SPI GP10,GP11,GP12
OPTION SYSTEM I2C GP6,GP7, SLOW
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION DEFAULT COLOURS GREEN, BLACK
OPTION KEYBOARD I2C
OPTION CPUSPEED (KHz) 200000
OPTION LCDPANEL CONSOLE ,, FF00
OPTION DISPLAY 26, 40
OPTION LCDPANEL ST7796SP, PORTRAIT,GP14,GP15,GP13,,INVERT
OPTION BACKLIGHT LCD 16
OPTION SDCARD GP17, GP18, GP19, GP16
OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5
OPTION PLATFORM PicoCalc
First I ran Flash_nuke and then 6.02. Unfortunately, still no connection:
Do I need to configure anything else on the Picocalc to enable communication? Otherwise, I’ll just revert to the bootloader and the old version.
I don’t know. I did nothing on the picocalc, used F2 in MMEdit:
C:\Users\Ernst\AppData\Local\MMedit5\untitled.bas
Uploading using:  'target port\:115200 s\picomite
Upload started
 failed!
Check port then try again
Not connected!
 Connected to COM4 at 115200
Uploading using:  'target port\COM4:115200 s\picomite
Upload started
NEW
AUTOSAVE N
Progress: 1/8
Upload completed 1
Saved 84 bytes
Time taken: 1003mS
RUN
[5] For n = 1 To 100
Error : N is not declared
FYI: I do not really use MMEdit, other user may be able to help you.
 ? mm.ver
 6.0201
> option list
PicoMite MMBasic RP2350A V6.02.01b0
OPTION KEYBOARD I2C
OPTION CPUSPEED (KHz) 380000
The latest V6.02.01B4 beta is now available on http://raspi1.mypi.co/download
B4 is better than previous attempts but still locks up on a unit with nothing but an RTC attached. I’m going to run a program that prints out a timer so I can see exactly how long it runs before locking up and see if it’s consistent.
am i correct in thinking this also doesn’t work with the uf2 loader?
Yes - this is the original version, very awkward to impossible to adapt.
@ernst I think I found a bug with ā€œStruct Loadā€ in 6.02.04Beta.
Below is a program which creates a file containing 2 structure records. It then reads the file back. I noticed when I read the last record, EOF() still returns FALSE and when I read record 3 (which doesn’t exist) it still says FALSE.
Can you test this for me to see if it’s a bug or am I doing something wrong…..thanks…brian
' bugtest.bas - test for possible bug
' Brian Osborne; 2026
Option Explicit
Option Default Integer
Dim TestFile1$="test1.tst"
TYPE myStruct
  recNum AS Integer
  date   AS String Length 10
  notes AS String Length 80
END TYPE
Dim dataFileRecLen
dataFileRecLen = Struct(SIZEOF "myStruct")
Print "Size of myStruct is "; dataFileRecLen
DIM rec AS myStruct
' create newfile with 2 records
' record 1....
rec.recNum = 1
rec.date = "2026-01-01"
rec.notes = "This is record 1."
?:?"Record 1 is...."
Struct Print rec
?"Writing record 1 to "; TestFile1$
Open TestFile1$ For Output As #9
Struct Save #9, rec
' record 2....
rec.recNum = 2
rec.date = "2026-02-28"
rec.notes = "This is record 2."
?:?"Record 2 is...."
Struct Print rec
?"Writing record 2 to "; TestFile1$
Struct Save #9, rec
Close #9
?TestFile1$; " closed."
' Now read the data back
?:?"Pausing for 15 seconds..."
Pause 15000
?:?"Reading "; TestFile1$
?"Opening file..."
Open TestFile1$ For Input As #9
?"EOF= ";eof(#9)
?"Reading record 1....."
Struct Load #9, rec
?"EOF= ";eof(#9)
?"Record 1 from file is..."
struct print rec
?"Reading record 2....."
Struct Load #9, rec
?"EOF= ";eof(#9)
?"Record 2 from file is..."
struct print rec
?"Attepting to read record 3....."
Struct Load #9, rec
?"EOF= ";eof(#9)
?"Record 3 from file is..."
struct print rec
Close #9
END
I did a test using my B4 (Pico 2H, COM5) and the official B4 (Pico 2 Plus, COM23) with the help of MMEdit, in both cases the program gave the expected result:
C:\Work\test.bas
Upload started
 failed!
Not connected!
C:\Work\test.bas
Uploading using:  'target port\COM5:115200 s\picomite
Upload started
NEW
AUTOSAVE N
Progress: 50/81
Upload completed 1
Saved 1520 bytes
Time taken: 1237mS
RUN
Size of myStruct is  104
Record 1 is....
MYSTRUCT:
  .RECNUM = 1
  .DATE = "2026-01-01"
  .NOTES = "This is record 1."
Writing record 1 to test1.tst
Record 2 is....
MYSTRUCT:
  .RECNUM = 2
  .DATE = "2026-02-28"
  .NOTES = "This is record 2."
Writing record 2 to test1.tst
test1.tst closed.
Reading test1.tst
Opening file...
EOF=  0
EOF=  0
MYSTRUCT:
  .RECNUM = 1
EOF=  1
MYSTRUCT:
  .RECNUM = 2
EOF=  1
MYSTRUCT:
  .RECNUM = 2
 08:09:41 Port: COM5 removed
 Disconnected
 08:10:27 Port: COM23 inserted
 failed!
 Connected to COM23 at 115200
> C:\Work\test.bas
Uploading using:  'target port\COM23:115200 s\picomite
Upload started
NEW
AUTOSAVE N
Progress: 50/81
Upload completed 1
Saved 1520 bytes
Time taken: 2525mS
RUN
Record 1 is....
MYSTRUCT:
  .RECNUM = 1
Record 2 is....
MYSTRUCT:
  .RECNUM = 2
test1.tst closed.
Reading test1.tst
Opening file...
EOF=  0
EOF=  0
MYSTRUCT:
  .RECNUM = 1
EOF=  1
MYSTRUCT:
  .RECNUM = 2
EOF=  1
MYSTRUCT:
  .RECNUM = 2
In both cases after reading record 2 the file is positioned at EOF and reading past EOF does not change EOF or the previous read data. Works as I would expect. If the medium would have been a magnetic tape (transport) then EOF indicates that the tape is positioned BEFORE the EOF marker, trying to read past EOF the transport moves past the EOF marker, notes that EOF is detected and moves the tape back to before the EOF marker. No data is read, only the status EOF is returned to the caller.
But you are right that something is not correct, in particular when comparing it to magnetic tape. With a magnetic tape EOF will not be reported after reading record 2 because the EOF marker has not yet been recognized. IMHO discussing this implementation in MMBasic could be very political, iirc basic has always worked this way :grinning_face:
Now for the not that nice reply. While writing the about the tape transport I had the PicoCalc next to me connected to MMEdit. Without any interaction the following was displayed:
  .RECNUM = 2
 08:21:53 Port: COM23 removed
 Disconnected
 08:21:54 Port: COM23 inserted
Total of 6 Mbytes PSRAM available
I saw the lines moving up, I heard the loudspeaker, but I did not a an error message :cry:. And the keyboard does not respond. Must try to repeat this with the official B4.
@BrianO
I received an update for this bug. The updated files are in the download area.
picocalc_v6.02.01b4_beta.pico1.uf2
picocalc_v6.02.01b4_beta.pico1_w.uf2
picocalc_v6.02.01b4_beta.pico2.uf2
picocalc_v6.02.01b4_beta.pico2_w.uf2
picocalc_v6.02.01b4_beta.zip
Wierd. Here is what shows on my pico.
I have a second test program which writes and reads data using Print #9 and Line Input #9 and EOF works as it’s supposed to.
I think I’ll reload the picomite firmware…..Brian
Thanks @ernst .
I keep getting ā€œConnection Refusedā€. Will keep trying and let you know the results of my testing….Brian
@ernst, I think you should either make your firewall not quite as strict or host your files somewhere else… I also had to download UF2’s for someone and email them to them because they simply couldn’t get past your firewall.
