# QMK firmware for uConsole keyboard
**URL:** <https://forum.clockworkpi.com/t/qmk-firmware-for-uconsole-keyboard/14410>\
**Category:** uConsole\
**Tags:** keyboard, firmware\
**Created:** [September 9, 2024, 6:56pm UTC](https://forum.clockworkpi.com/t/qmk-firmware-for-uconsole-keyboard/14410 "2024-09-09T18:56:56Z")\
**Showing post:** 151
**Author:** ![beams](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/beams/32/15232_2.png) [@beams](https://forum.clockworkpi.com/u/beams)\
**Post date:** [January 9, 2026, 3:00pm UTC](https://forum.clockworkpi.com/t/qmk-firmware-for-uconsole-keyboard/14410/151 "2026-01-09T15:00:45Z")
Thank you for the comments and testing the firmware. I agree that ~~shift~~ select works better with two hands and FN is too far away from the pointer position. I will test it and merge it later today.
The web tester is coded against the key code in this firmware, so it could be slightly different with other firmware - most importantly it shows keys are registering.
the trackball movement is optimized for the 5 inch screen & resolution. Hope it makes a much more enjoyable - I initially thinking about changing trackball to touchpad, but it seems not necessary now!
Regarding USB power issues, I saw these report - I am sure there is a power brownout issue that triggers QMK going into DFU mode - because the main board is designed for cm3. I tried to reproduce it by plugin all sorts of my common usb devices (thunderbolt nvm, iPhone, usb drives, iPod.. they all seem to be fine for me - via hacker-gadgets usb & usb-c ports) at least I can’t reproduce it for the moments.
_[View the full topic](https://forum.clockworkpi.com/t/qmk-firmware-for-uconsole-keyboard/14410)._
