# Raspberry Pi Zero 2 On PicoCalc
**URL:** <https://forum.clockworkpi.com/t/raspberry-pi-zero-2-on-picocalc/17946>\
**Category:** PicoCalc\
**Tags:** os, hardware, retroarch\
**Created:** [June 11, 2025, 2:36am UTC](https://forum.clockworkpi.com/t/raspberry-pi-zero-2-on-picocalc/17946 "2025-06-11T02:36:19Z")\
**Showing post:** 328
**Author:** ![lolus](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/lolus/32/15141_2.png) [@lolus](https://forum.clockworkpi.com/u/lolus)\
**Post date:** [December 27, 2025, 12:08am UTC](https://forum.clockworkpi.com/t/raspberry-pi-zero-2-on-picocalc/17946/328 "2025-12-27T00:08:21Z")
Hi, I am working on getting this to work on radxa zero3w. currently I have keyboard working and I am like 90% there to have working display, if anyone have any idea why it does not work it would be great.
display does not even flicker, I know it still works as I have put in the pico back in and it worked just fine, it also worked with raspberry pi zero, but that thing is gutless and does not have wifi
pins:
```auto
SPI3_MOSI_M1 GPIO4_C3
SPI3_MISO_M1 GPIO4_C5
SPI3_CLK_M1 GPIO4_C2
SPI3_CS0_M1 GPIO4_C6
RESET GPIO3_C1
DC GPIO3_B2
I am using display init.txt from this gitrepo : [picocalc\_trixie/picomipi.txt at main · ironat/picocalc\_trixie · GitHub](https://github.com/ironat/picocalc_trixie/blob/main/picomipi.txt)
> **picolcd.txt**
> ```command
> delay 120
> command 0x28
> command 0xCB 0x39 0x2C 0x00 0x34 0x02
> command 0xCF 0x00 0xC1 0x30
> command 0xED 0x64 0x03 0x12 0x81
> command 0xE8 0x85 0x00 0x78
> command 0xEA 0x00 0x00
> command 0xF7 0x20
> command 0xC0 0x23
> command 0xC1 0x10
> command 0xC5 0x3E 0x28
> command 0xC7 0x86
> command 0x36 0x48
> command 0x21
> command 0x3A 0x55
> command 0xB1 0x00 0x11
> command 0xB6 0x08 0x82 0x27
> command 0xF2 0x02
> command 0x26 0x01
> command 0xB4 0x02
> command 0xE0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00
> command 0xE1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F
> command 0x11
> delay 64
> command 0x29
> delay 20
here is my dts, I am 90 % it is correct as I can see the driver initialize
> **DTS**
> ```GNU
> /dts-v1/;
> /plugin/;
> compatible = "radxa,zero3"; /* Update to match your SoC */
> fragment@0 {
> target = <&spi3>; /* Correct SPI3 node */
> __overlay__ {
> #address-cells = <1>;
> #size-cells = <0>;
> pinctrl-names = "default";
> pinctrl-0 = <&spi3m1_pins &spi3m1_cs0>; /* Reference correct pin configuration */
> status = "okay"; /* Enable SPI3 */
> panel: panel@0 {
> compatible = "picolcd", "panel-mipi-dbi-spi";
> reg = <0>;
> spi-max-frequency = <24000000>;
> width-mm=<43>;
> height-mm=<43>;
> reset-gpios = <&gpio3 17 0>; //GPIO3_C1
> dc-gpios = <&gpio3 10 0>; // GPIO3_B2
> write-only;
> debug = <3>;
> panel-timing {
> hactive = <320>;
> vactive = <320>;
> hback-porch = <0>;
> vback-porch = <0>;
> clock-frequency = <24000000>;
> hfront-porch = <0>;
> hsync-len = <0>;
> vfront-porch = <0>;
> vsync-len = <0>;
> fragment@1 {
> target = <&pinctrl>; /* Ensure this matches your pin controller node */
> __overlay__ {
> spi3m1_pins: spi3m1-pins {
> rockchip,pins = <
> 4 23 3 0 /* GPIO4_C2 as SPI3_CLK_M1 */
> 4 19 3 0 /* GPIO4_C3 as SPI3_MOSI_M1 */
> 4 21 3 0 /* GPIO4_C5 as SPI3_MISO_M1 */
> 4 24 3 0 /* GPIO4_C6 as SPI3_CS0_M1 */
here is `dmesg | grep mipi` that shows that it is initializing the driver, btw I got more info here as I added `drm.debug=0x06` to extraargs in armbianEnv.txt
> **dmesg | grep mipi**
> ````auto
> [10.872660] panel-mipi-dbi-spi spi3.0: Looking up power-supply property in node /spi@fe640000/panel@0 failed
> [10.872699] panel-mipi-dbi-spi spi3.0: supply power not found, using dummy regulator
> [10.873047] [drm:mipi_dbi_spi_init] SPI speed: 24MHz
> [10.873442] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] size=136 version=1
> [10.873478] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 11
> [10.873502] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] sleep 120ms
> [10.873522] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 28
> [10.873543] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command cb 39 2c 00 34 02
> [10.873564] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command cf 00 c1 30
> [10.873585] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command ed 64 03 12 81
> [10.873605] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command e8 85 00 78
> [10.873624] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command ea 00 00
> [10.873644] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command f7 20
> [10.873664] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command c0 23
> [10.873683] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command c1 10
> [10.873702] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command c5 3e 28
> [10.873722] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command c7 86
> [10.873741] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 36 48
> [10.873761] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 21
> [10.873780] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 3a 55
> [10.873800] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command b1 00 11
> [10.873819] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command b6 08 82 27
> [10.873838] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command f2 02
> [10.873858] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 26 01
> [10.873877] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command b4 02
> [10.873896] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command e0 0f 31 2b 0c 0e 08 4e f1 37 07 10 03 0e 09 00
> [10.873916] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command e1 00 0e 14 03 11 07 31 c1 48 08 0f 0c 31 36 0f
> [10.873936] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 11
> [10.873956] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] sleep 64ms
> [10.873976] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] command 29
> [10.873996] panel-mipi-dbi-spi spi3.0: [drm:panel_mipi_dbi_commands_from_fw] sleep 20ms
> [10.874219] [drm:mipi_dbi_dev_init_with_formats] rotation = 0
> [10.874849] panel-mipi-dbi-spi spi3.0: [drm:drm_sysfs_connector_hotplug_event] [CONNECTOR:31:SPI-1] generating connector hotplug event
> [10.874906] [drm] Initialized panel-mipi-dbi 1.0.0 20220103 for spi3.0 on minor 1
> [10.875295] panel-mipi-dbi-spi spi3.0: [drm:__drm_fb_helper_initial_config_and_unlock] test CRTC 0 primary plane
> [10.875323] panel-mipi-dbi-spi spi3.0: [drm:drm_fb_helper_generic_probe] surface width(320), height(320) and bpp(16)
> [10.876142] panel-mipi-dbi-spi spi3.0: [drm:drm_mode_addfb2] [FB:36]
> [10.876672] panel-mipi-dbi-spi spi3.0: [drm] fb1: panel-mipi-dbid frame buffer device
> [11.167646] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: enter mipi csi2 hw probe!
> [11.168105] rockchip-mipi-csi2-hw fdfb0000.mipi-csi2-hw: probe success, v4l2_dev:mipi-csi2-hw!```
also here is the proof that GPIO pins from dts are getting set correctly, I got this by using command `sudo gpioinfo -c 3 | grep output`
> **activated pins**
> ```auto
> line 10: "PIN_18" output consumer="dc"
> line 16: unnamed output
> line 17: "PIN_22" output consumer="reset"
> line 27: unnamed output active-low consumer=board-antenna
thanks in advance
_[View the full topic](https://forum.clockworkpi.com/t/raspberry-pi-zero-2-on-picocalc/17946)._
