# RetroArch looks not like it should be
**URL:** <https://forum.clockworkpi.com/t/retroarch-looks-not-like-it-should-be/782>\
**Category:** Emulators\
**Tags:** retroarch\
**Created:** [July 26, 2018, 12:26am UTC](https://forum.clockworkpi.com/t/retroarch-looks-not-like-it-should-be/782 "2018-07-26T00:26:16Z")\
**Showing post:** 4
**Author:** ![fr500](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/fr500/32/389_2.png) [@fr500](https://forum.clockworkpi.com/u/fr500)\
**Post date:** [July 26, 2018, 12:48am UTC](https://forum.clockworkpi.com/t/retroarch-looks-not-like-it-should-be/782/4 "2018-07-26T00:48:38Z")
> [@RetroArch Megathread](https://forum.clockworkpi.com/t/retroarch-megathread/716/2):
> Common Problems I messed up input and I can’t press anything. If you really did mess up input the easiest solution is to start over. Close RetroArch SSH into your GS and then do cd ~/.config/retroarch rm retroarch.cfg wget https://raw.githubusercontent.com/clockworkpi/GameShellDocs/master/retroarch.cfg I removed my config and now when I start RetroArch it looks weid If you are working without a config you’re using RetroArch global defaults, which means 3x window size and XMB theme. The easie…
_[View the full topic](https://forum.clockworkpi.com/t/retroarch-looks-not-like-it-should-be/782)._
