Until now, I hadn’t thought it’s necessary to screw the CM4/5 onto the adapter board, but, concerned by reports of worn CM contact strips and encouraged by @fmatray in the thread ‘Issue after Update’, I decided to go ahead and give it a try.
I used M2.5 x 6 mm plastic screws and nuts, as well as self-printed spacer rings (2.7 mm x 4.4 mm x 1.4 mm).
I filed down two of the screw heads, as they would otherwise have been too thick.
I fed the screws through the circuit boards upside down from below and tightened the nuts from above. This allowed me to use all four mounting points, even though components were in the way at the two lower mounting points.
I’m satisfied with the mounting itself. However, I’m not at all sure whether I’m happy with the overall solution. Whilst there’s no longer any risk of the CM becoming detached from the adapter, the force exerted when removing the rear plate now pulls on the adapter board, which is merely clipped into place. It remains to be seen whether the clips will withstand the forces in the long run…
