# Stuck in command line
**URL:** <https://forum.clockworkpi.com/t/stuck-in-command-line/2320>\
**Category:** GameShell\
**Tags:** gameshell\
**Created:** [January 19, 2019, 12:56am UTC](https://forum.clockworkpi.com/t/stuck-in-command-line/2320 "2019-01-19T00:56:18Z")\
**Showing post:** 8
**Author:** ![guu](https://avatars.discourse-cdn.com/v4/letter/g/7ab992/32.png) [@guu](https://forum.clockworkpi.com/u/guu)\
**Post date:** [January 19, 2019, 9:16am UTC](https://forum.clockworkpi.com/t/stuck-in-command-line/2320/8 "2019-01-19T09:16:30Z")
got you problem
I guess you did an update in launcher
there is a bug between versions updating…
> [@Bug in Launcher 1.23](https://forum.clockworkpi.com/t/bug-in-launcher-1-23/2139):
> I just installed the newest Launcher update into ClockworkOS 1.21. Now every time it boots it starts up in a windowed mode, displaying the launcher in a window titled “pygame window”. If I switch to LauncherGo, it reboots into the normal display, but looses a lot of features in Settings.
> [@Bug in Launcher 1.23](https://forum.clockworkpi.com/t/bug-in-launcher-1-23/2139/2):
> need a little fix in /home/cpi/.bashrc
> remove bottom part of `.bashrc` , starts at this line to the end
> ```auto
> if [-f /tmp/autologin]
> Replace with:
> ```auto
> if [-f ~/launcher/.cpirc]; then
> . ~/launcher/.cpirc
> fi
> In os v0.21 image, we changed `~/.bashrc`
if you don’t know how to edit text under ssh use vim ,let me know
here is the whole file of ~/.bashrc
> **[gameshell /home/cpi/.bashrc - Pastebin.com](https://pastebin.com/eJRPg93A)**
> Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
if you changed `~/.bashrc` successfully
just `sudo reboot`
_[View the full topic](https://forum.clockworkpi.com/t/stuck-in-command-line/2320)._
