Succesful Screen O.C 100hz
uConsole CM5: internal screen at 100 Hz (limit ~104 Hz)
Short version: the uConsole’s internal panel will run well above its stock ~60 Hz with custom xrandr modes. On my unit the limit is 104 Hz, and I run it at 100 Hz to leave some margin.
Tested on: uConsole with CM5, ak-rex kernel, Kali, X11 + Xfce (xfwm4), Xorg modesetting driver. One unit only, so your panel revision may behave differently.
What I found
  • Stock mode on this kernel is 720x1280 at a requested 61.020 MHz, with timings h 720 750 765 780 / v 1280 1288 1290 1306, which works out to about 60 Hz.
  • Use your own kernel’s timings. Older cwu50 driver versions use htotal 803. Custom modes built from those numbers looked wrong even at 60 Hz on this kernel. The scripts below read the timings from your stock mode, so they adapt to your kernel automatically.
  • The DSI clock snaps to nearby rates the hardware can produce. Here it always landed within 0.7%, and that didn’t affect the results.
  • 60 to 104 Hz gave a clean picture. A sweep in 1 Hz steps showed anything above 104 isn’t usable, even though a coarser pass had marked 105 and 110 as clean. At 115 and 120 Hz, about a third of the screen was warped.
  • 120 Hz, which would pace 60 fps content evenly, isn’t reachable. Even with zero horizontal blanking, 120 Hz needs a higher pixel clock than the ~106 MHz where it breaks, so tweaking the timings can’t get there.
  • 70 and 75 Hz each looked off once and fine on a rerun. A mode switch occasionally comes up wrong, so retest anything that fails once.
  • Switching to a custom mode re-runs the panel init, and the picture often looks crisper and brighter than it does right after boot.
  • At 100 Hz, glxgears holds a steady ~99.98 FPS.
Target Requested clock (MHz) Actual DPI clock (MHz) Result
stock 61.020 61.111 baseline (~60.0 Hz)
60 61.121 61.111 clean
65 66.214 66.667 clean
70 71.308 71.428 clean (off once, fine on rerun)
75 76.401 76.190 clean (off once, fine on rerun)
80 81.494 81.482 clean
85 86.588 86.667 clean
90 91.681 91.666 clean
95 96.775 not captured clean
100 101.868 not captured clean, glxgears ~99.98 FPS
104 105.943 not captured clean (limit)
105 106.961 not captured not usable in 1 Hz sweep
110 112.055 not captured not usable in 1 Hz sweep
115 117.148 not captured ~1/3 of screen warped
120 122.242 not captured ~1/3 of screen warped
Scripts
hzsweep: step through refresh rates
This builds each mode from your stock timings and holds it for a few seconds. Press g to mark a rate as good, Enter to skip to the next one, and q to quit. It always switches back to your normal mode when it stops, including on Ctrl+C. If sudo is unlocked, it also prints the actual DSI clocks.
sudo install -m755 /dev/stdin /usr/local/bin/hzsweep <<'EOF'
#!/bin/bash
# usage: hzsweep <start> [end] [step] [secs]   run from the stock mode; decimals ok
S=${1:?usage: hzsweep <start> [end] [step] [secs]}
E=${2:-$1}
STEP=${3:-5}
SECS=${4:-10}
clk(){ sudo -n awk 'tolower($1)~/dsi|mipi/ && $2>0 {printf "  %s %.3f MHz\n",$1,$5/1e6}' /sys/kernel/debug/clk/clk_summary 2>/dev/null; }
OUT=$(xrandr | awk '/^DSI/{print $1; exit}')
read -r CUR SCLK HD HSS HSE HT VD VSS VSE VT FL <<<"$(xrandr --verbose | awk -v o="$OUT" '
  $1==o{f=1;next} f&&/^[^ \t]/{f=0}
  f&&/\*current/{n=$1;c=$3+0;fl="";for(i=4;i<=NF;i++)if($i~/Sync$/)fl=fl" "$i
    getline;h=$3" "$5" "$7" "$9;getline;print n,c,h,$3,$5,$7,$9 fl;exit}')"
[ -z "$VT" ] && { echo "could not read $OUT mode"; exit 1; }
awk -v c="$SCLK" -v t="$HT" -v v="$VT" -v n="$CUR" -v f="$FL" 'BEGIN{printf "stock %s: %.3f MHz = %.2f Hz %s\n",n,c,c*1e6/(t*v),f}'
echo "timings: h $HD $HSS $HSE $HT  v $VD $VSS $VSE $VT"
clk
GOOD=""
trap 'xrandr --output "$OUT" --mode "$CUR"; echo; echo "reverted to $CUR"; [ -n "$GOOD" ] && echo "marked good:$GOOD"' EXIT
for HZ in $(awk -v s="$S" -v e="$E" -v st="$STEP" 'BEGIN{for(h=s;h>=e-1e-9;h-=st)printf "%g ",h}'); do
  CLK=$(awk -v h="$HZ" -v t="$HT" -v v="$VT" 'BEGIN{printf "%.3f",t*v*h/1e6}')
  NAME="s$HZ"
  xrandr --delmode "$OUT" "$NAME" 2>/dev/null
  xrandr --rmmode "$NAME" 2>/dev/null
  xrandr --newmode "$NAME" "$CLK" $HD $HSS $HSE $HT $VD $VSS $VSE $VT $FL
  xrandr --addmode "$OUT" "$NAME"
  xrandr --output "$OUT" --mode "$NAME" || { echo "$HZ Hz rejected"; continue; }
  sleep 1
  printf '\n=== %s Hz (%s MHz)\n' "$HZ" "$CLK"
  clk
  printf 'g=good q=quit enter=next (auto %ss) ' "$SECS"
  read -rsn1 -t "$SECS" k
  case "$k" in
    g) GOOD="$GOOD $HZ"; echo "marked";;
    q) break;;
  esac
done
EOF
Usage:
sudo -v
hzsweep 120 60 5
To hold a single rate for 2 minutes:
hzsweep 100 100 5 120
hzset: apply a rate
This reads the timings from the panel’s preferred (stock) mode and switches to the rate you give it.
sudo install -m755 /dev/stdin /usr/local/bin/hzset <<'EOF'
#!/bin/bash
# usage: hzset <hz>   builds a mode from the panel's stock (preferred) timings
HZ=${1:-100}
[ -z "$OUT" ] && exit 0
read -r HD HSS HSE HT VD VSS VSE VT FL <<<"$(xrandr --verbose | awk -v o="$OUT" '
  f&&/\+preferred/{fl="";for(i=4;i<=NF;i++)if($i~/Sync$/)fl=fl" "$i
    getline;h=$3" "$5" "$7" "$9;getline;print h,$3,$5,$7,$9 fl;exit}')"
[ -z "$VT" ] && { echo "could not read $OUT preferred mode"; exit 1; }
NAME="s$HZ"
xrandr --newmode "$NAME" "$CLK" $HD $HSS $HSE $HT $VD $VSS $VSE $VT $FL 2>/dev/null
xrandr --addmode "$OUT" "$NAME" 2>/dev/null
EOF
hzset 100
Apply at login (Xfce)
install -Dm644 /dev/stdin ~/.config/autostart/hzset.desktop <<'EOF'
[Desktop Entry]
Type=Application
Name=Panel 100Hz
Exec=sh -c "sleep 3; /usr/local/bin/hzset 100"
EOF
To undo it:
rm ~/.config/autostart/hzset.desktop
Verifying
  • glxgears (from the mesa-utils package) should report roughly your target rate in FPS. That confirms the system is really outputting that rate.
  • UFO Test: Frame Skipping Checker in Chromium, plus a slow-shutter phone photo (around 1/10 s). An even, unbroken run of lit squares means the panel shows every frame. Firefox’s vsync on X11 is unreliable for this test, and the “unverified browser” banner shows on every Linux browser, so you can ignore it. I haven’t done the photo test yet, so results from anyone who does would be welcome.
Caveats
  • Short tests are low risk. The worst case is a garbled screen until the script reverts. Keep HDMI or SSH available anyway.
  • A higher refresh rate means more power draw and more heat in the panel’s driver chip. After a while at your chosen rate, check that the corner of the panel above the ribbon cable isn’t noticeably warmer than at stock.
  • If your rotation setup runs xrandr with --auto or --mode after login, it will reset the panel to stock.
  • I’ve only tested this on X11, not Wayland.
Related: tearing on the internal screen
The panel is natively portrait and gets rotated in software under X11, so tearing shows up as a vertical line. Setting xfwm4’s vblank mode fixed it on my unit (compositing must be enabled). To test live:
xfwm4 --replace --vblank=xpresent &
To make it permanent:
xfconf-query -c xfwm4 -p /general/vblank_mode -n -t string -s xpresent
If xpresent doesn’t fix it, try glx instead. Wayland (labwc) avoids the tearing problem entirely.
100hz is a huge improvement, specifically mouse movements go from borderline unacceptable to very usable.
