Two hours with Claude produced Minesweeper, Solitaire, and Freecell and I feel nothing
This project brought me no joy at all. I sat down at the Claude Code prompt at 7:30am this morning with my mug of tea and gave it the prompt to produce the games Minesweeper, Solitaire, and Freecell. And I was done by 9:30am
After two hours, it gave me this: GitHub - Dzubin/picocalc-games: FreeCell, Klondike Solitaire and Minesweeper for the ClockworkPi PicoCalc (Raspberry Pi Pico / Pico 2) · GitHub
UF2 files are here: Releases · Dzubin/picocalc-games · GitHub
I didn’t feel any zing of dopamine that I would normally get during the creative process because I didn’t create anything. This is sad code. But it works. I’ll probably play the games casually while I’m watching TV. It’s all Claude produced. Sigh. Some screenshots are in the README.md file
Thomas Dzubin
This is part of why I don’t use AI to program. I love programming. I love creating. Herding a bot to do it for me would suck all the joy out of it, even if it produced the code faster, more easily. Likewise, I love the hunt of stalking a bug and ultimately fixing it. If I had a bot find all my bugs for me, it would be no fun.
I agree with that. And for me, there’s another aspect to it: I want to know my (!) code. I want to know how it works under the hood and be able to take responsibility for it.
Every generation has had this argument: machine code versus assembler, assembler versus Fortran, then libraries, IDEs, frameworks. Each time, something real was lost, and each time the interesting work moved up a level. For me the fun now is in deciding what to build, testing it on real hardware, and finding bugs in other people’s libraries to send back. But if the hands-on part is what you love, keep doing it by hand. People still knit, and it isn’t because machines can’t make sweaters.
The difference between a compiler and an LLM is that a compiler mechanistically turns higher-level code into lower-level code, while an LLM pulls code that is a composite of everything in its training set out of thin air, which may or may not actually do what you want it to do, in response to vague English-language prompts.
You can understand what a compiler will do; e.g. I could hand-code everything my zeptoforth will generate in assembly if I really felt like it, but I don’t do so because it would be a lot of extra effort for litttle gain. (Yes, I do recognize that this is largely due to the fact that I wrote zeptoforth’s code generator myself.)
With an LLM, though, you don’t truly know what it will spit out ─ to be sure you need to audit every line of code it generates ─ specifically because LLM’s aren’t mechanistic in nature and because the directions given to the LLM are human-language in nature rather than being given in a programming language.
The reason why LLM’s may seem like they can magically do things that seem impossible is that they have already been done by other people and are in the LLM’s’ training sets. Other people have almost certainly written Minesweeper, Solitaire, and Freecell games which one’s LLM has been trained against, for instance.
My thoughts on this situation: it completely depends on what you define as fun.
Replacing what you find fun with AI agents is definitely the wrong approach.
I will use my recent work here as examples.
I created three emulators with Claude Opus: the Acorn Atom, the Jupiter Ace and the Tangerine Oric-1/Atmos. Creating the emulators was not the task I wanted to do. I have already written emulators before, so it was a “been here, done that” situation. I find enjoyment working through the manuals like it was 1983 and learning how to use this cool new computer I just acquired. I cannot get these computers in Canada (expensive to buy and ship here) and the PicoCalc is the perfect form factor for emulating retro computers. I also find a lot of enjoyment in others’ projects in this space, such as VirtualT, emu8, PicoCalcTRS…
Another example is the shell, another “I did this before.” I needed a way to manage these emulators and other programs’ configuration and files. The fun is using the shells, including/etc/profile and autoexec.bat/config.sys, to make the PicoCalc more fun to use.
Also there is the difference between “vide coding” and “agentic engineering”. I do not like 100% of the activities in coding. I don’t like writing unit tests, or documentation, or boilerplate code, or specifications. I use AI to do this. If you look at the PicoCalc Text Starter, all the “important” code is written by me by my own hand with zero AI involvement. I researched how the peripherals worked, read the docs and asked for advice in the community here. This work I really enjoyed and has a lot of fun doing it. The tests and songs, an AI agent wrote those.
My point is to use AI to rid yourself of the slog, use it to amplify your abilities to build ideas that would take years of your time to get to the fun part or that kill the the fun out of it. Get to the point where you can have fun with your creative ideas and enjoy your PicoCalc investment!
THAT’S why You’re the “Tabemann”!!!
Glad to see you’re still online!!
Thanks again for all your help in the past!!
Keep up the great work!!
Tripletee
If only more people had this sentiment. I mean it’s a negative one but is what the world really needs.
I think you have to think bigger. Figure out what you could never have created without the AI assistant tooling.
Find the limits of what’s possible on the PicoCalc.
I think that lack of joy stems from recreating other people’s IP not creating new IP that you thought up.
For me AI is a great unblocking tool, it solves a bunch of Yak shaving problems that get in the way of exploring some creative idea.
And when I’m using the AI to recreate other people’s IP, I’m doing it as a learning exercise, even when it’s still mediated by AI, I’m learning what implementation techniques work and don’t work, what are the trade offs? What decisions did the original author have to make? Can I solve the “problem” with other constraints the original didn’t have.
When photography arrived, it completely disrupted oil painting. The amazing folks that came out the other side invented impressionism and abstraction.
