Ubuntu on NVME - uConsole does not power up
Hi there,
So I am trying to install Rex’s Ubuntu on the NVME drive, but after flashing and powering up, the screen remains dark- it does not even light up.
When Ubuntu is flashed to a microSD card, it works fine.
When I flash the Trixie image to NVME, it works fine.
I flash to NVME using RPI imager on Trixie running from microSD card in the uConsole.
Any idea where the problem might be?
My setup: CM5 Lite 16GB, HackerGadget’s Adapter board for CM5 + Battery board with NVME + expansion board [USB A+C + RJ45.]
have you changed boot order in the config?
yes, when I flash trixie to the NVME it works fine. I have noticed in the config.txt that there was dtparam=pciex1=off - so i removed “=off” - as it is in the trixie config - still no joy
I have the exact same problem. Trixie runs fine from my 1TB and 2TB NVMe drives but Ubuntu won’t run on either.
