# uConsole A06 LTE module autostart on boot solution
**URL:** <https://forum.clockworkpi.com/t/uconsole-a06-lte-module-autostart-on-boot-solution/11000>\
**Category:** uConsole\
**Tags:** tinkering, hardware\
**Created:** [September 20, 2023, 7:50pm UTC](https://forum.clockworkpi.com/t/uconsole-a06-lte-module-autostart-on-boot-solution/11000 "2023-09-20T19:50:02Z")\
**Showing post:** 3
**Author:** ![SuperMarioSF](https://yyz1.discourse-cdn.com/flex029/user_avatar/forum.clockworkpi.com/supermariosf/32/6712_2.png) [@SuperMarioSF](https://forum.clockworkpi.com/u/SuperMarioSF)\
**Post date:** [January 19, 2024, 2:54pm UTC](https://forum.clockworkpi.com/t/uconsole-a06-lte-module-autostart-on-boot-solution/11000/3 "2024-01-19T14:54:19Z")
First of all… yup I fricked it up, the filename is wrong. it should be `uConsoleLTE.service`. by the way there should be no `*` symbol in the command, remove them. (Why you add those things in?)
Second, have you ran `sudo systemctl daemon-reload` **before** running those commands?
Last: You may want to look here for more information: [https://forum.clockworkpi.com/t/uconsole-lte-modem-how-to-guide-for-a06-with-9001-stock-firmware](https://forum.clockworkpi.com/t/uconsole-lte-modem-how-to-guide-for-a06-with-9001-stock-firmware)
The GitHub Gist is updated to fix those filename issues.
_[View the full topic](https://forum.clockworkpi.com/t/uconsole-a06-lte-module-autostart-on-boot-solution/11000)._
