UConsole - Google FI - Hotspot Issue
I have a uconsole working properly with a googleFI DATAONLY sim card installed. I can confirm by disabling the wifi that the LTE is connected and sending/receiving data.
When I toggle on hotspot mode I can connect to the network that is created by uConsole but no cellular data is being sent or received on the tethered device. Uconsole still receives data however through cellular.
I went through a bunch of troubleshooting and hit a wall. Basically from what I can tell the hotspot requires IPV4 to share cellular data with the tethered device but the googleFI data only sim is assigning IPV6.
I have tried multiple resets to attempt to get googleFI/Tmobile to handshake over IPV4, it seems like a configuration on their side (probably deliberately to prevent hotspotting).
Is there a work around to this or am I SOL?
TY!
How are you setting up the hotspot? This is most likely an issue with that software, not a uconsole specific issue, the 4g card is just a usb dongle after all, nothing that special.
Do you have tethering in your data plan? It’s just like a phone to need to pay extra to be able to tether/hotspot.
Sorry, I’m uncertain how to answer your question maybe you can give me some more details? I followed the guides to set up cellular and enable tethering.
I took the sim out of the uconsole and put it into a glocalme hotspot and it works fine. I think that the issue is probably just that googlefi does not officially support tethering and that it does not work in every configuration.
my question is, what exactly did you do and which guides did you follow?
