UConsole vs Gameshell —
Aside from the built-in keyboard and mobile data option, what are the biggest differences between the new UConsole and the Gameshell? I’d go with the UConsole for newness and added functionality, but I hate that it doesn’t have a real D-Pad for gaming, which the Gameshell obviously does and is more geared toward. Still, would love to hear pros and cons for one over another (other than the obvious A-Z keys). Do they use the same OS? Does UConsole have any added features or abilities over the Gameshell? Has UConsole switched to a touchscreen display?
Quite a lot of things actually, but let’s answer your questions first
Both use Linux, but that somewhere were thing stop. The GameShell have its own custom shell. I f the uConsole is does not get a custom version of the OS compared to the DevTerm, this will act like a normal Linux desktop system.
Yes
  • Keyboard
  • Trackpad
  • Battery easier to change
No.
As for the main differences:
  • The Gameshell is smaller than the uConsole
  • The Gameshell input is more typical from a console than the uConsole
  • The Gameshell have a smaller screen resolution (320x240) where the uConsole have a higher resolution (1280x720)
  • And the screen ratio is also different. The GameShell is a 4:3, the uConsole 16:9
  • The uConsole have a metal body where the gameshell is plastic
  • The Gameshell have a fairly old CPU compared to what we can put on the uConsole, though the RISC-V option is way less powerful than the SoC used on the GameShell.
  • The uConsole SoC can be changed easily as it is on a module, and there are multiple options available. On the Gameshell changing the SoC mean basically changing the whole mainboard.
