What could I use a Xiao ESP32 in a uConsole for?
I was browsing Printables for stuff related to the uConsole and came across these mounts meant to house a Seeed Xiao ESP32 https://www.printables.com/model/1716113-xiao-esp32-internal-mount-for-uconsole https://www.printables.com/model/1803008-seeed-studio-xiao-esp32-uconsole-mount.
I know, so far, that they can be used to flash with Biscuit firmware to make wardriving nodes, among other things. But what could I use one inside a uConsole for?
Use it for the same things you’d use it out side for. I’ve use one with the diy biscuit firmware and the biscuit manager app on Waydroid with gps fed over gpsd. Right now I’m running vord on it for a skimmer dector.
You might be able to use it to add inputs to the uconsole like triggers and joysticks?
I imagine the point of having an ESP32 inside my uConsole is being able to interface with it within the uConsole itself.
Now void C5 sounds interesting and mainly I do want to use the ESP32 for pentesting and counter-surveillance stuff.
