WiFi dropping after apt update
I have a uconsole running trixie 64 bit. I ran sudo apt update; sudo apt upgrade and when it updated wapsupplicant the wifi dropped and never worked again.
I spent many hours troubleshooting this and finally found the solution. The update replaced the Debian wpasupplicant with the raspbian one. Same version, just with a +rpi1 at the end. This broke everything.
To fix it, first connect your uconsole to the network (I had an ethernet connection) and run:
sudo nmcli con modify “netplan-wlan0-<my_network_ssid>” 802-11-wireless-security.pmf 0 && sudo apt install wpasupplicant=2:2.10-24 && sudo systemctl restart wpa_supplicant NetworkManager
And say Y when it asks if you want to downgrade wpasupplicant.
To make the change permanent, pin the repo so apt prefers Debian over rpi
printf ‘Package: wpasupplicant\nPin: origin “archive.raspberrypi.com”\nPin-Priority: -1\n’ | sudo tee /etc/apt/preferences.d/99-wpasupplicant-debian
Hope this can save someone the hours of frustration I went through.
