AIOV2_CTL install issue
Is there a way to get the GUI to show up in the taskbar on every boot? I have used the autostart command, but that does not put the icon in the taskbar.
I installed the aiov2_ctl GUI; however, when I start the app, it returns the error: “Python is not installed.” When I install Python, the system tells me Python is already installed and that it’s the latest version. aiov2_ctl works fine from the command line. Does anyone have any ideas as to what’s going on?
You need to use a Trixie image. It will not work on bookworm. I tried and failed over and over. Maybe we can convince the dev to make a fork for bookworm but the on trixie it works as advertised.
This is happening to me currently on Trixie. It’s looking for it in the wrong spot so I made a shortcut for it
nano ~/.local/share/applications/aiov2.desktop
[Desktop Entry]
Name=AIOv2 Controller
Exec=env QT_QPA_PLATFORM=xcb /usr/bin/python3 /usr/local/bin/aiov2_ctl --gui
Type=Application
Categories=Utility;
Terminal=
false
Lmk if that works around works for you too. I don’t want to admit how long I spent figuring this out.
I am having issues anyone able to help please been scratching my head on this one for a while @AceMedia any fix for this?
Is this the same problem I was having:
particularly:
I got an error about PyQt6 not being installed so had to change:
Path to PyGPSClient executable
export PATH=“/home/”$(logname)“/.pygpsclient/bin:$PATH”
to:
export PATH=“${PATH}:/home/$(logname)/.pygpsclient/bin”
using: sudo nano ~/.profile
I think things get broken as kernels and stuff get updated. Hopefully the developers will update their work and things go back to normal.
I think this may fix it
This seems to fix the error i was getting with python q6 not installed run the below command.
Fix ownership so your regular user owns the venv
sudo chown -R $USER:$USER ~/.pygpsclient
Install PyQt6 inside the venv (not the system Python)
~/.pygpsclient/bin/pip3 install --ignore-installed PyQt6 --break-system-packages
Verify
aiov2_ctl --status
But now the issue i have now is AIOv2 GUI already running but i cant see it any sugestions anyone?
