The option list for backlight LCD shows the following:
Option backlight LCD 96
I would like to increase that to 150
So I do the following
I type into the prompt, option backlight LCD 155
This results in an immediate brightness of the screen as desired
Upon reboot, I’m back to the dim original 96.
How do I get this option into the boot option list permanently. The alt brightness keys work. Typing the full option as desired works but I cannot get it into the option list.
Pico 2 with latest uf2 in bios 1.6
I know the command ‘option save’ no longer exist, and it is my understanding that simply typing in
Option backlight LCD 155
Then cycling to off and back on should update the option list.
It does not. But it can be that the power management IC was having a problem with the batteries. Under “normal” conditions, using the latest bios, PicoMite/WebMite 6.1+ periodically request the backlight setting from the bios. Under some conditions the request can be delayed.
The symptoms were as follows, without knowing the batteries were low, and all I had to do was look at the yellow light indicator.
I would set option backlight LCD 200
The display will brighten, I would select the picocalc off and back on.
Request option list
And find option backlight LCD 32.
I would do this on subsequent attempts over the next half hour trying to determine without realizing the batteries were low, that the option backlight LCD would randomly come up with numbers regardless of my option request ranging from 32 to 96.
As soon as the batteries were swapped out for fully charged and a green LED indicator, my option request became permanent and were reflected by the option backlight LCD displaying my requested setting.
I know what the word soon means, but that is what I did thinking that the system was selecting a lower brightness factor based on battery health.
