Hi…i am a new user here. As per my knowledge plasma screen went black and never came back; no pun intended. On advice from a friend, instead of replacing the whole display panel/PDP module(S42AX-YB01) I was told that more than likely the culprit would be the a ribbon cable. More specifically, the top ribbon cable on the Upper Y buffer board which is located in the upper left quadrant if looking at it from behind. I just took all of the backing of the tv off to access the cable and this is where the issue lies.
