"Error: Invalid Address - Resetting" happening randomly when using "option autorun 1"
Hey there! I have a very very simple start script that is saved on flash 1 (literally just a few “print” and a “play tone etc.”).
It often works, but in some cases the error in the title, “Error: Invalid Address - Resetting”, flashes very briefly and then resets the autorun 1 option. It’s weird because it happens completely randomly.
What does it mean? And how can I fix this? Thank you!!
Try removing lines until you find what is triggering the error. Sounds like something is executing before everything is fully configured. Does it only happen on power-up or also with a reset?
By a reset you mean what exactly? Launching and relaunching the program normally never brings any errors, only ever on startup
