Fixing uConsole power delivery limitations with CM5
Have you resolved the issue of audible hissing from the speakers when the battery level is low?
did you hand solder this? or with a heat gun?
Nope. But there seems to be a workaround: https://forum.clockworkpi.com/t/cm5-speaker-static-got-you-down/19834?u=silentbyte
Did this replacement. I used a 6.3V 220uF 227J instead. it seems to work fine.
Tried connecting and disconnecting a few external drives and devices… (directly on the uconsole). the keyboard did not seem to disconnect.
Devices on my USB Bus
  1. thumbdrive (on USBA - expansion board AIOv1)
  2. USB A drawing power for my CM5 Fan (mainboard)
  3. AIOv1 board with 1TB NVME attached on USBC connector
  4. USBC connected to either Ethernet dongle or external SATA drive
I used to experience period keyboard disconnection, which i can observe in the logs.
don’t see this anymore.
does anyone know if the latest hackergadgets upgrade board does anything to address these things? cc @vileer
No, I didn’t fix this issue in the upgrade kit.
Ok so I replaced the C513 with 10PCS B 6.3V 220uF 227J Tantalum Capacitor B Type(3528) SMD 1210 | Surface Mount Tantalum Electrolytic Capacitor 3.2mm*2.5mm: Amazon.com: Industrial & Scientific and the keyboard and trackpad still lose power when I try to connect an esp32C board to the usb-A port. Any thoughts?
Bumping… Sorry. Hoping to get some advice.
you try have chargin your devise i just solder in paralells not reemplace give me more stable connection , have good batteries? i ussualy conect esp32 and other “arduinos” and dont givme problems may be can batteries
