Im out of ideas so I figured Id see if anyone else had a thought.
This is my second Uconsole build. The first one had the full HG loadout. I opted to not use the SDR board on this one. The CM5 was pulled from my first build where I tested every OS that is currently available. EEPROM is current.
When I power it on via battery or usb C, the CPU fan starts up but nothing happens.
So far I have tried:
-Every image that is out for the cm5 and I have also re burned most of them two or three times.
-Triple checked and reseated every ribbon cable including the display to make sure that it wasn’t working and I just wasn’t seeing it.
-Double checked the cm5 was seated in the carrier board and then inside the chassis properly multiple times.
I have a micro HDMI cable ordered to see what happens on an external display.
I know this is a far fetch but when you power the unit on, do you have battery in the slots?
I had the same issue when trying to boot to the NVME that the power usage at startup caused some modules not to be “reached” even if I had a laptop USB-c charger connected.
While you arent using any NVME you have a FAN and the AC1200 dongle which maybe can cause the same issue?
an old school usb power supply is a better choice than a modern PD one, the uconsole doesn’t do PD it just tries to draw as much current as needed on 5v
I did about 80% of my troubleshooting with two freshly charged Samsung cells. Then the last 20% of troubleshooting I had the cells in and a charger connected.
This was one of the first things I checked. Went over it about 5 times making sure the CM5 was properly seated and the clips on either side are snapped in once the adapter board is seated to the main board. Wish there was another way for me to fully test the HG adapter board.
I wonder what the deal is? My first uconsole had the full HG upgrade and everything worked flawlessly the first go. I wanted to build a second one without all the SDR functionality so I went with the base package. Crazy that the one with the least amount of bolt ons is having issues.
