CONFIG FOR KEYBINDS
(saved as yayo.joystick.amgp)
<?xml version="1.0" encoding="UTF-8"?>
<joystick configversion="19" appversion="3.2.3">
<!--The SDL name for a joystick is included for informational purposes only.-->
<sdlname>ClockworkPI DevTerm</sdlname>
<!--The Unique ID for a joystick is included for informational purposes only.-->
<uniqueID>03000000af1e00002400000010010000</uniqueID>
<sets>
<set index="1">
<axis index="5">
<center_value>0</center_value>
<min_value>-32767</min_value>
<max_value>32767</max_value>
<throttle>normal</throttle>
</axis>
<axis index="4">
</axis>
<axis index="3">
</axis>
<axis index="2">
<maxZone>16000</maxZone>
<axisbutton index="1">
<mousespeedx>30</mousespeedx>
<mousespeedy>30</mousespeedy>
<slots>
<slot>
<code>1</code>
<mode>mousemovement</mode>
</slot>
</slots>
</axisbutton>
<axisbutton index="2">
<slots>
<slot>
<code>2</code>
</slot>
</slots>
</axisbutton>
</axis>
<axis index="1">
<slots>
<slot>
<code>3</code>
</slot>
</slots>
</axisbutton>
<slots>
<slot>
<code>4</code>
</slot>
</slots>
</axisbutton>
</axis>
<button index="4">
<slots>
<slot>
<slots>
<slot>
<code>0x1000022</code>
<mode>keyboard</mode>
</slot>
<slot>
<code>0x44</code>
</slot>
</slots>
<mode>mix</mode>
</slot>
</slots>
</button>
<button index="3">
<slots>
<slot>
<code>0x1000017</code>
</slot>
</slots>
</button>
<button index="2">
<slots>
<slot>
<code>1</code>
<mode>mousebutton</mode>
</slot>
</slots>
</button>
<button index="1">
<slots>
<slot>
<code>0x1000016</code>
</slot>
</slots>
</button>
</set>
</sets>
</joystick>
1. in i3 I added: exec --no-startup-id antimicrox --profile yayo.joystick.amgp --hidden ######## note your path to the config may differ but WHATEVER.joystick.amgp is the typical extension/naming convention ############
2.##### you can name the config above the same as I have here and as long as it points to the right path it should be fine ################
heh.
