@Laika, I installed the SD_Boot loader, and it works for the included demos on the Pico, but when I loaded my PicoMite binary I just got a black screen.
In my CMakeLists.txt, I uncommented the set(SDBOOT true)
at the top of the file, and used set(COMPILE PICO)
, which should have buillt the usual PICO firmware and then added the necessary linker option which is at the bottom of the file.
cmake_minimum_required(VERSION 3.13)
# Valid builds are PICO, PICOUSB, VGA, VGAUSB, HDMI(rp2350 only), HDMIUSB(rp2350 only), WEB
set(PICOCALC true)
set(SDBOOT true)
# Compile for PICO 1 Board
set(COMPILE PICO)
# Compile for PICO 2 Board
#set(COMPILE PICORP2350)
#set(COMPILE WEBRP2350)
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "PICOUSBRP2350" )
set(PICO_PLATFORM rp2350)
if (COMPILE STREQUAL "WEBRP2350")
set(PICO_BOARD pico2_w)
else()
set(PICO_BOARD pimoroni_pga2350)
endif()
else()
set(PICO_PLATFORM rp2040)
if (COMPILE STREQUAL "WEB")
set(PICO_BOARD pico_w)
else()
set(PICO_BOARD pico)
endif()
endif()
include(pico_sdk_import.cmake)
project(PicoMite C CXX ASM)
set(CMAKE_C_STANDARD 11)
set(CMAKE_CXX_STANDARD 17)
#set(PICO_NO_COPRO_DIS 1)
pico_sdk_init()
add_executable(PicoMite
PicoMite.c
Memory.c
regex.c
MMBasic.c
Operators.c
Custom.c
Functions.c
Commands.c
FileIO.c
ff.c
ffsystem.c
ffunicode.c
mmc_stm32.c
Draw.c
Editor.c
XModem.c
MM_Misc.c
External.c
MATHS.c
Onewire.c
I2C.c
SPI.c
Serial.c
SPI-LCD.c
BmpDecoder.c
GPS.c
Audio.c
CFunction.c
picojpeg.c
lfs.c
lfs_util.c
hxcmod.c
VS1053.c
aes.c
if (COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350" )
target_sources(PicoMite PRIVATE
SSD1963.c
Touch.c
GUI.c
cJSON.c
mqtt.c
MMMqtt.c
MMTCPclient.c
MMtelnet.c
MMntp.c
MMtcpserver.c
tftp.c
MMtftp.c
MMudp.c
set_source_files_properties(cJSON.c PROPERTIES COMPILE_FLAGS -Os)
target_include_directories(PicoMite PRIVATE
${CMAKE_CURRENT_LIST_DIR}
${CMAKE_CURRENT_LIST_DIR}/.. # for our common lwipopts
Pico_enable_stdio_usb(PicoMite 1)
endif()
if ((COMPILE STREQUAL "PICO") OR (COMPILE STREQUAL "PICOUSB") OR (COMPILE STREQUAL "PICORP2350") OR (COMPILE STREQUAL "PICOUSBRP2350") OR (COMPILE STREQUAL "WEBRP2350"))
SSD1963.c
Touch.c
GUI.c)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB")
USBKeyboard.c
else()
Keyboard.c
mouse.c
endif()
if(COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "PICOUSBRP2350")
upng.c
# assember.S
endif()
set_source_files_properties(mmc_stm32.c PROPERTIES COMPILE_FLAGS -O2)
set_source_files_properties(ff.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GUI.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(BmpDecoder.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(GPS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(I2C.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(lfs.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(picojpeg.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(regex.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(hxcmod.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(MATHS.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(Editor.c PROPERTIES COMPILE_FLAGS -Os)
set_source_files_properties(aes.c PROPERTIES COMPILE_FLAGS -Os)
pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteI2S.pio)
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "WEB")
pico_define_boot_stage2(slower_boot2 ${PICO_DEFAULT_BOOT_STAGE2_FILE})
target_compile_definitions(slower_boot2 PRIVATE PICO_FLASH_SPI_CLKDIV=4)
pico_set_boot_stage2(PicoMite slower_boot2)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "VGARP2350")
pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteVGA.pio)
# pico_generate_pio_header(PicoMite ${CMAKE_CURRENT_LIST_DIR}/PicoMiteI2S.pio)
endif()
if (COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
Pico_enable_stdio_usb(PicoMite 0)
target_include_directories(PicoMite PRIVATE ${CMAKE_CURRENT_SOURCE_DIR}
${CMAKE_CURRENT_SOURCE_DIR}/usb_host_files
else()
endif()
pico_enable_stdio_uart(PicoMite 0)
pico_add_extra_outputs(PicoMite)
pico_set_printf_implementation(PicoMite compiler)
target_compile_options(PicoMite PRIVATE -DNDEBUG
-DPICO_STDIO_USB_ENABLE_RESET_VIA_VENDOR_INTERFACE=0
-DPICO_ADC_CLKDIV_ROUND_NEAREST
-DPICO_XOSC_STARTUP_DELAY_MULTIPLIER=64
-DPICO_CLOCK_AJDUST_PERI_CLOCK_WITH_SYS_CLOCK
-DPICO_FLASH_SIZE_BYTES=16777216
-DPICO_CORE1_STACK_SIZE=0x00
-DPICO_MALLOC_PANIC
-O2
-Wall)
# all RP2350 variants
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "WEBRP2350" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
target_compile_options(PicoMite PRIVATE -Drp2350
-DPICO_FLASH_SPI_CLKDIV=4
-DPICO_PIO_USE_GPIO_BASE
endif()
# all PicoMite variants - enable the gui
if (COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "PICORP2350" OR COMPILE STREQUAL "PICOUSBRP2350")
target_compile_options(PicoMite PRIVATE -DPICOMITE
-DPICO_HEAP_SIZE=0x1000
-DGUICONTROLS
-DPICO_CORE0_STACK_SIZE=0x1000
endif()
# all VGA variants
if (COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
target_compile_options(PicoMite PRIVATE -DPICOMITEVGA
-DPICO_HEAP_SIZE=0x2000
-DPICO_CORE0_STACK_SIZE=0x2000
endif()
# HDMI variants
if (COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "HDMIUSB")
-DHDMI
endif()
#Web variants need more heap
if(COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350")
target_compile_options(PicoMite PRIVATE -DPICOMITEWEB
-DPICO_HEAP_SIZE=0x4000
-DGUICONTROLS
-DCYW43_HOST_NAME="WebMite"
-DPICO_CYW43_ARCH_POLL
-DPICO_CORE0_STACK_SIZE=0x4000
endif()
#USB variants
if (COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "VGAUSBRP2350" OR COMPILE STREQUAL "HDMIUSB")
target_compile_options(PicoMite PRIVATE -DUSBKEYBOARD
endif()
#special case WEB RP2350 gets the GUI controls
if(COMPILE STREQUAL "WEBRP2350")
target_compile_options(PicoMite PRIVATE -DGUICONTROLS
endif()
#set the PICOCALC flag
if(PICOCALC STREQUAL "true")
target_compile_options(PicoMite PRIVATE -DPICOCALC
endif()
target_link_libraries(PicoMite
pico_stdlib
hardware_flash
hardware_irq
hardware_adc
hardware_pwm
hardware_i2c
hardware_spi
hardware_dma
hardware_exception
hardware_pio
if(COMPILE STREQUAL "VGAUSB" OR COMPILE STREQUAL "PICOUSB" OR COMPILE STREQUAL "HDMIUSB" OR COMPILE STREQUAL "PICOUSBRP2350" OR COMPILE STREQUAL "VGAUSBRP2350")
tinyusb_host
tinyusb_board
pico_multicore
endif()
if(COMPILE STREQUAL "VGA" OR COMPILE STREQUAL "PICO" OR COMPILE STREQUAL "HDMI" OR COMPILE STREQUAL "VGARP2350" OR COMPILE STREQUAL "PICORP2350")
pico_multicore
endif()
pico_rand
endif()
if(COMPILE STREQUAL "WEB" OR COMPILE STREQUAL "WEBRP2350" )
pico_cyw43_arch_lwip_poll
endif()
if(SDBOOT STREQUAL "true")
pico_set_linker_script(PicoMite ${CMAKE_SOURCE_DIR}/memmap_sdcard_app.ld)
endif()
Build output:
cpi@clockworkpi:~/picocalc/PicoMiteAllVersions/build $ cmake ..; make
Using PICO_SDK_PATH from environment ('/home/cpi/pico/pico-sdk')
PICO_SDK_PATH is /home/cpi/pico/pico-sdk
Target board (PICO_BOARD) is 'pico'.
Using board configuration from /home/cpi/pico/pico-sdk/src/boards/include/boards/pico.h
Pico Platform (PICO_PLATFORM) is 'rp2040'.
-- Defaulting build type to 'Release' since not specified.
Defaulting compiler (PICO_COMPILER) to 'pico_arm_cortex_m0plus_gcc' since not specified.
Configuring toolchain based on PICO_COMPILER 'pico_arm_cortex_m0plus_gcc'
Defaulting PICO_GCC_TRIPLE to 'arm-none-eabi'
-- The C compiler identification is GNU 12.2.1
-- The CXX compiler identification is GNU 12.2.1
-- The ASM compiler identification is GNU
-- Found assembler: /usr/bin/arm-none-eabi-gcc
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/arm-none-eabi-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/arm-none-eabi-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
Build type is Release
-- Found Python3: /usr/bin/python3 (found version "3.11.2") found components: Interpreter
TinyUSB available at /home/cpi/pico/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040; enabling build support for USB.
BTstack available at /home/cpi/pico/pico-sdk/lib/btstack
cyw43-driver available at /home/cpi/pico/pico-sdk/lib/cyw43-driver
lwIP available at /home/cpi/pico/pico-sdk/lib/lwip
mbedtls available at /home/cpi/pico/pico-sdk/lib/mbedtls
CMake Warning at /home/cpi/pico/pico-sdk/tools/Findpicotool.cmake:30 (message):
No installed picotool with version 2.1.1 found - building from source
It is recommended to build and install picotool separately, or to set
PICOTOOL_FETCH_FROM_GIT_PATH to a common directory for all your SDK
projects
Call Stack (most recent call first):
/home/cpi/pico/pico-sdk/tools/CMakeLists.txt:138 (find_package)
/home/cpi/pico/pico-sdk/tools/CMakeLists.txt:493 (pico_init_picotool)
/home/cpi/pico/pico-sdk/src/cmake/on_device.cmake:56 (picotool_postprocess_binary)
CMakeLists.txt:155 (pico_add_extra_outputs)
Downloading Picotool
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cpi/picocalc/PicoMiteAllVersions/build
[ 0%] Built target picotoolForceReconfigure
[ 1%] Creating directories for 'picotoolBuild'
[ 1%] No download step for 'picotoolBuild'
[ 2%] No update step for 'picotoolBuild'
[ 2%] No patch step for 'picotoolBuild'
[ 3%] Performing configure step for 'picotoolBuild'
Not searching for unused variables given on the command line.
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- Check for working C compiler: /usr/bin/cc - skipped
-- Check for working CXX compiler: /usr/bin/c++ - skipped
.//home/cpi/picocalc/PicoMiteAllVersions/build/_deps/picotool/
-- Using the single-header code from /home/cpi/picocalc/PicoMiteAllVersions/build/_deps/picotool-src/lib/nlohmann_json/single_include/
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
-- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
PICOTOOL_NO_LIBUSB is set - no USB support will be built
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cpi/picocalc/PicoMiteAllVersions/build/_deps/picotool-build
[ 4%] Performing build step for 'picotoolBuild'
[ 67%] Built target mbedcrypto
[ 76%] Built target mbedx509
[ 86%] Built target mbedtls
[ 88%] Built target errors
[ 89%] Built target elf
[ 92%] Built target bintool
[ 94%] Built target elf2uf2
[100%] Built target picotool
[ 5%] Performing install step for 'picotoolBuild'
Install the project...
-- Install configuration: "Release"
[ 6%] Performing test step for 'picotoolBuild'
picotool v2.1.2-develop (Linux, GNU-12.2.0, Release)
[ 6%] Completed 'picotoolBuild'
[ 6%] Built target picotoolBuild
[ 6%] Creating directories for 'pioasmBuild'
[ 7%] No download step for 'pioasmBuild'
[ 8%] No update step for 'pioasmBuild'
[ 9%] No patch step for 'pioasmBuild'
[ 9%] Performing configure step for 'pioasmBuild'
loading initial cache file /home/cpi/picocalc/PicoMiteAllVersions/build/pico-sdk/src/rp2_common/pico_cyw43_driver/pioasm/tmp/pioasmBuild-cache-Release.cmake
-- Configuring done
-- Generating done
-- Build files have been written to: /home/cpi/picocalc/PicoMiteAllVersions/build/pioasm
[ 10%] Performing build step for 'pioasmBuild'
[100%] Built target pioasm
[ 11%] Performing install step for 'pioasmBuild'
[ 11%] Completed 'pioasmBuild'
[ 11%] Built target pioasmBuild
[ 11%] Generating PicoMiteI2S.pio.h
[ 11%] Built target PicoMite_PicoMiteI2S_pio_h
[ 11%] Building ASM object CMakeFiles/slower_boot2.dir/home/cpi/pico/pico-sdk/src/rp2040/boot_stage2/compile_time_choice.S.o
[ 12%] Linking ASM executable slower_boot2.elf
[ 12%] Built target slower_boot2
[ 13%] Generating slower_boot2.bin
[ 13%] Generating slower_boot2_padded_checksummed.S
[ 14%] Building ASM object CMakeFiles/slower_boot2_library.dir/slower_boot2_padded_checksummed.S.o
[ 14%] Built target slower_boot2_library
[ 14%] Building C object CMakeFiles/PicoMite.dir/PicoMite.c.o
/tmp/cc5MfIx6.s: Assembler messages:
/tmp/cc5MfIx6.s:14018: Warning: ignoring changed section attributes for .text
[ 15%] Building C object CMakeFiles/PicoMite.dir/Memory.c.o
[ 15%] Building C object CMakeFiles/PicoMite.dir/regex.c.o
[ 16%] Building C object CMakeFiles/PicoMite.dir/MMBasic.c.o
[ 17%] Building C object CMakeFiles/PicoMite.dir/Operators.c.o
[ 17%] Building C object CMakeFiles/PicoMite.dir/Custom.c.o
[ 18%] Building C object CMakeFiles/PicoMite.dir/Functions.c.o
[ 19%] Building C object CMakeFiles/PicoMite.dir/Commands.c.o
[ 19%] Building C object CMakeFiles/PicoMite.dir/FileIO.c.o
[ 20%] Building C object CMakeFiles/PicoMite.dir/ff.c.o
[ 21%] Building C object CMakeFiles/PicoMite.dir/ffsystem.c.o
[ 21%] Building C object CMakeFiles/PicoMite.dir/ffunicode.c.o
[ 22%] Building C object CMakeFiles/PicoMite.dir/mmc_stm32.c.o
[ 22%] Building C object CMakeFiles/PicoMite.dir/Draw.c.o
[ 23%] Building C object CMakeFiles/PicoMite.dir/Editor.c.o
[ 24%] Building C object CMakeFiles/PicoMite.dir/XModem.c.o
[ 24%] Building C object CMakeFiles/PicoMite.dir/MM_Misc.c.o
[ 25%] Building C object CMakeFiles/PicoMite.dir/External.c.o
[ 26%] Building C object CMakeFiles/PicoMite.dir/MATHS.c.o
[ 26%] Building C object CMakeFiles/PicoMite.dir/Onewire.c.o
[ 27%] Building C object CMakeFiles/PicoMite.dir/I2C.c.o
[ 28%] Building C object CMakeFiles/PicoMite.dir/SPI.c.o
[ 28%] Building C object CMakeFiles/PicoMite.dir/Serial.c.o
[ 29%] Building C object CMakeFiles/PicoMite.dir/SPI-LCD.c.o
[ 29%] Building C object CMakeFiles/PicoMite.dir/BmpDecoder.c.o
[ 30%] Building C object CMakeFiles/PicoMite.dir/GPS.c.o
[ 31%] Building C object CMakeFiles/PicoMite.dir/Audio.c.o
[ 31%] Building C object CMakeFiles/PicoMite.dir/CFunction.c.o
[ 32%] Building C object CMakeFiles/PicoMite.dir/picojpeg.c.o
[ 33%] Building C object CMakeFiles/PicoMite.dir/lfs.c.o
[ 33%] Building C object CMakeFiles/PicoMite.dir/lfs_util.c.o
[ 34%] Building C object CMakeFiles/PicoMite.dir/hxcmod.c.o
[ 35%] Building C object CMakeFiles/PicoMite.dir/VS1053.c.o
[ 35%] Building C object CMakeFiles/PicoMite.dir/aes.c.o
[ 36%] Building C object CMakeFiles/PicoMite.dir/SSD1963.c.o
[ 36%] Building C object CMakeFiles/PicoMite.dir/Touch.c.o
[ 37%] Building C object CMakeFiles/PicoMite.dir/GUI.c.o
[ 38%] Building C object CMakeFiles/PicoMite.dir/Keyboard.c.o
[ 38%] Building C object CMakeFiles/PicoMite.dir/mouse.c.o
[ 39%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_stdlib/stdlib.c.o
[ 40%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_gpio/gpio.c.o
[ 40%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2040/pico_platform/platform.c.o
[ 41%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_platform_panic/panic.c.o
[ 42%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/hardware_claim/claim.c.o
[ 42%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_sync/sync.c.o
[ 43%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_sync_spin_lock/sync_spin_lock.c.o
[ 43%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_irq/irq.c.o
[ 44%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_irq/irq_handler_chain.S.o
[ 45%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_sync/sem.c.o
[ 45%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_sync/lock_core.c.o
[ 46%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_sync/mutex.c.o
[ 47%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_sync/critical_section.c.o
[ 47%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_time/time.c.o
[ 48%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_time/timeout_helper.c.o
[ 50%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_timer/timer.c.o
[ 50%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_util/datetime.c.o
[ 51%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_util/pheap.c.o
[ 51%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/common/pico_util/queue.c.o
[ 52%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_uart/uart.c.o
[ 53%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_clocks/clocks.c.o
[ 53%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_pll/pll.c.o
[ 54%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_vreg/vreg.c.o
[ 55%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_watchdog/watchdog.c.o
[ 55%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_ticks/ticks.c.o
[ 56%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_bootrom/bootrom.c.o
[ 57%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_bootrom/bootrom_lock.c.o
[ 57%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_boot_lock/boot_lock.c.o
[ 58%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_flash/flash.c.o
[ 58%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_xosc/xosc.c.o
[ 59%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_divider/divider.S.o
[ 60%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_runtime/runtime.c.o
[ 60%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_runtime_init/runtime_init.c.o
[ 61%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_runtime_init/runtime_init_clocks.c.o
[ 62%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_runtime_init/runtime_init_stack_guard.c.o
[ 62%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_bit_ops/bit_ops_aeabi.S.o
[ 63%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_divider/divider_hardware.S.o
[ 64%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_double/double_aeabi_rp2040.S.o
[ 64%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_double/double_init_rom_rp2040.c.o
[ 65%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_double/double_math.c.o
[ 65%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_double/double_v1_rom_shim_rp2040.S.o
[ 66%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_int64_ops/pico_int64_ops_aeabi.S.o
[ 67%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_float/float_aeabi_rp2040.S.o
[ 67%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_float/float_init_rom_rp2040.c.o
[ 68%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_float/float_math.c.o
[ 69%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_float/float_v1_rom_shim_rp2040.S.o
[ 69%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_malloc/malloc.c.o
[ 70%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_mem_ops/mem_ops_aeabi.S.o
[ 71%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_atomic/atomic.c.o
[ 71%] Building CXX object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_cxx_options/new_delete.cpp.o
[ 72%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_standard_binary_info/standard_binary_info.c.o
[ 72%] Building ASM object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_crt0/crt0.S.o
[ 73%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_clib_interface/newlib_interface.c.o
[ 74%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_stdio/stdio.c.o
[ 74%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/reset_interface.c.o
[ 75%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c.o
[ 76%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb_descriptors.c.o
[ 76%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_unique_id/unique_id.c.o
[ 77%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_flash/flash.c.o
[ 78%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_xip_cache/xip_cache.c.o
[ 78%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040/dcd_rp2040.c.o
[ 79%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/portable/raspberrypi/rp2040/rp2040_usb.c.o
[ 79%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/device/usbd.c.o
[ 80%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/device/usbd_control.c.o
[ 81%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/audio/audio_device.c.o
[ 81%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/cdc/cdc_device.c.o
[ 82%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/dfu/dfu_device.c.o
[ 83%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/dfu/dfu_rt_device.c.o
[ 83%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/hid/hid_device.c.o
[ 84%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/midi/midi_device.c.o
[ 85%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/msc/msc_device.c.o
[ 85%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/net/ecm_rndis_device.c.o
[ 86%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/net/ncm_device.c.o
[ 86%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/usbtmc/usbtmc_device.c.o
[ 87%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/vendor/vendor_device.c.o
[ 88%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/class/video/video_device.c.o
[ 88%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/tusb.c.o
[ 89%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/lib/tinyusb/src/common/tusb_fifo.c.o
[ 90%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_fix/rp2040_usb_device_enumeration/rp2040_usb_device_enumeration.c.o
[ 90%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_adc/adc.c.o
[ 91%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_i2c/i2c.c.o
[ 92%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_spi/spi.c.o
[ 92%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_dma/dma.c.o
[ 93%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_exception/exception.c.o
[ 93%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/hardware_pio/pio.c.o
[ 94%] Building C object CMakeFiles/PicoMite.dir/home/cpi/pico/pico-sdk/src/rp2_common/pico_multicore/multicore.c.o
[ 95%] Linking CXX executable PicoMite.elf
[ 95%] Built target PicoMite
[ 96%] Building ASM object pico-sdk/src/rp2040/boot_stage2/CMakeFiles/bs2_default.dir/compile_time_choice.S.o
[ 97%] Linking ASM executable bs2_default.elf
[ 97%] Built target bs2_default
[ 98%] Generating bs2_default.bin
[100%] Generating bs2_default_padded_checksummed.S
[100%] Building ASM object pico-sdk/src/rp2040/boot_stage2/CMakeFiles/bs2_default_library.dir/bs2_default_padded_checksummed.S.o
[100%] Built target bs2_default_library
I don’t see any mention of memmap_sdcard_app.ld
in the output though, so I’m not sure if that’s being used or not.
