Many thanks for the answer.
Sounds like this ?
Sounds like this ?
I tried the blacklist fix on my teensy but it didn’t work.
Just seen this today. So I must use stock firmware to be able to do this? I cannot use ak-rex bookwork image, kali linux etc?
I followed the instructions and it worked no problem on the arch arm cfw.
Somehow on the kali version it would give me an error. With the stock image it went flawless. Thank you OP!
Your problem appears only when qmk firmware was installed or on stock firmware as well ?
Well, now even a small usb-disk could set off the protection …
Installed the prerequistes listed, tried using the included command to flash from stock.
Error produced maple upload command not found?
My problem only appeared not being on stock rom. On stock rom it went flawless.
Just like my situation ? USB power cut after usb disk was attached ?
(post deleted by author)
usbhid.mousepoll=2 usbhid.kbpoll=3 usbhid=jspoll=2
I noticed that the issue with plugging something that draws power into the USB port killing the keyboard had went away. I suddenly had no issue plugging in my teensy. I turns out the overclock I had applied completely resolved the issue. The only setting that matters is the over voltage in /boot/config.txt. Just add in the following
over_voltage=6
Did some testing and over_voltage_delta=100000 (equivalent to over_voltage=4) was enough to avoid the USB power protection issue when plugging in a drone flight controller. I think over_voltage_delta is preferred.
Where can I make this change? Thanks
https://www.raspberrypi.com/documentation/computers/config_txt.html
/boot/firmware/config.txt
I tried added over_voltage=6, keyboard still loses power then a thumb drive is inserted. Also, tried over_voltage_delta=100000 with the same result. any ideas?
̶F̶Y̶I̶,̶ ̶I̶ ̶i̶n̶s̶t̶a̶l̶l̶e̶d̶ ̶i̶t̶ ̶o̶n̶ ̶t̶h̶e̶ ̶K̶a̶l̶i̶ ̶i̶n̶s̶t̶a̶l̶l̶a̶t̶i̶o̶n̶.̶ ̶I̶t̶ ̶i̶s̶ ̶p̶r̶e̶t̶t̶y̶ ̶m̶u̶c̶h̶ ̶u̶p̶ ̶t̶o̶ ̶d̶a̶t̶e̶.̶ ̶I̶t̶ ̶f̶a̶i̶l̶e̶d̶ ̶t̶h̶e̶ ̶f̶i̶r̶s̶t̶ ̶t̶i̶m̶e̶,̶ ̶w̶o̶r̶k̶e̶d̶ ̶t̶h̶e̶ ̶s̶e̶c̶o̶n̶d̶.̶
Yeah.. unfortunately I have found a problem. After the uconsole times out and screen goes off the keyboard doesn’t come back on properly, the shortcuts don’t work anymore.
If I reconnect the USB hub the momentary power break resets it and the shortcuts work again.
Ill try usbreset tomorrow.
Does anyone have a video on how to make this work? I was able to update the keyboard stock firmware but can’t figure out how to do this version. I make it all the way to the part on terminal that say, waiting for device, exit witch ctrl-C. I press Fn-Esc but nothing happens.
