I wanted a portable spreadsheet I’d actually use on the PicoCalc, so I ported sc. It’s the text-mode spreadsheet James Gosling wrote in 1982, kept alive on Unix ever since: small, fast, and complete enough for real work. Budgets, loan tables, logs, unit conversions.
What it does on the PicoCalc:
- 64 x 32 characters, so 6 columns are visible at once
- sc’s formulas and functions (@sum, @avg, @pmt, the date functions and more), formats, colour and its 16 pages of help
- CSV files open and save, so sheets go to and from Excel or LibreOffice (CSV keeps values, not formulas)
- ready-made date, time, money and percent formats
- @now uses the clock that settime, VirtualT or the FTP server set
- room for about 6,000 cells; if you go past that, it offers to save your work and tells you what happened instead of crashing
Install: unzip, copy the pico2-apps and sc folders to the SD card, pick sc from the menu. GUIDE.TXT walks you through a first sheet in ten minutes, and there are four sample sheets to poke at.
One warning: sc is a vi-flavoured Unix program, so keys are case-sensitive (f and F are different commands) and Esc doesn’t always mean “get me out”. GUIDE.TXT covers the handful of keys you need.
Built with Claude (Anthropic’s AI) doing most of the coding; I did the testing on real hardware and made the calls. It’s an alpha, so please report problems as GitHub issues.
Thanks to Blair Leduc for the PicoCalc drivers and shell this is built on, and to Gosling and the long line of people who kept sc going.
