After much struggle, we finally got the PicoCalc & PicoMite working with the Pico 2/rp2350. I used @pelrun‘s pico 2 bootloader uf2 and bin from
I also used their PicoMite-pico2.uf2 from
I flashed the keyboard using PicoCalc_BIOS_v1.4.bin from
I can now boot and load PicoMite just fine. Unfortunately, during all this the fragile screen did its thing and now we need a new one.
Which brings me to the serial connection. I could connect to the Pico 1 just fine, even after also updating it to @pelrun‘s bootloader and PicoMite-pico1.uf2. But when I try to connect with the Pico 2 plugged in, I get nothing at all. On the Pico 1, while on the bootloader menu screen, pressing up/down on the picocalc keyboard would echo to the screen (something like “entry selected”). And then after loading PicoMite you’d have the full interactive session you’d expect. On the Pico 2, I get neither echos when selecting from the bootloader nor any response at all when in PicoMite. I just see the USB COM port, I connect to it, and just get a blank screen.
I have the same thing happen with both putty and MMEdit.
Any suggestions?
It seems like I could also try @ernst‘s 1.6 BIOS from
and PicoMiteRP2350V6.02.01R0 from
Do you think that would fix it? At this point, we’ve spent a great deal of yesterday and today working on it, so we’re taking a break.
But if that’s what it takes we can go that route.
