Side Sockets on PicoCalc
Is there any way to use the sockets labeled UART0_RX, UART0_TX, UART1_RX, UART1_TX from MMBasic? If so, how?
from the manual: “COM1, COM2 Can be used for asynchronous serial I/O (UART0 and UART1 pins on the Pico datasheet).”
and also:
OPTION SERIAL CONSOLE
uartapin, uartbpin [,B]
Specify that the console be accessed via a hardware serial port (instead
of virtual serial over USB).
‘uartapin’ and ‘uartbpin’ can be any valid pair of rx and tx pins for either
COM1 or COM2. The order that they are specified is not important.
The speed defaults to 115200 baud but can be changed with OPTION
BAUDRATE. Adding the “B” parameter means output will go to "B"oth
the serial port and the USB.
Then after setting them up in options you could just call them as needed.
such as: OPEN comspec$ AS [#]fnbr
you could choose your own if you wanted to (within reason):
SETPIN rx, tx, COM1 Allocate the pins to be used for serial port COM1.
Valid pins are RX: GP1, GP13 or GP17
TX: GP0, GP12, GP16 or GP28
SETPIN rx, tx, COM2 Allocate the pins to be used for serial port COM2.
Valid pins are RX: GP5, GP9 or GP21
TX: GP4, GP8 or GP20
a quick grep of the manual will give you other ideas too :smiley:
Are you talking about the lower half of the pins? Those belong to the motherboard and have to be accessed through the STM32 (I think?). I know the upper pins, GP4 and GP5 can be configured for serial communication pretty easily in PicoMite Basic. I am not sure how easy it would be use the lower pins.
You’re right about the pins labeled with GP but the lower ones (UART0, 1, etc.) aren’t Pico pins.
UART0_TX and UART0_RX are connected to the Pico’s GP0 and GP1 and can be used trivially. It’s only the UART1 and USB pins which aren’t (and the USB pins aren’t even connected to anything unless you change a dipswitch setting.)
Do you know what dipswitch has to be changed? Are UART1 pins connected to GP4 and 5 (COM2) after the change?
UART0 is always connected to GP0/GP1 on the Pico connector.
UART1 is always connected to the STM32 and can’t be used from the Pico at any time.
I was a little mistaken about the USB pins - they’re also permanently connected to the STM32. The dipswitch simply connects the USB-C socket to it as well.
I can’t seem to make UART0 work. When I connected to GP4 and GP5, I could use COM2 but when I try UART0_TX and UART0_RX, I can’t get anything through on COM1.
Update: I don’t know what happened but now I am getting a serial console on COM1 so now I can keep a console on COM1 and use COM2 for other data. I plan on connecting a serial printer to it.
Thank you for your help!
I spoke too soon.
When I use COM1 (UART0_TX and UART0_RX) I can type on the PicoCalc and it shows up in the terminal but nothing I type on the terminal shows up on the PicoCalc.
When I use COM2 (GP4 and GP5) communication works both ways.
I have been looking at the uart sockets on the side of the picocalc and I don’t really think they are useful without modification. The usbc connector is ordinarily routed to a usb-serial device (the CH340) and from there to UART0 on the pico. If you connect the usbc to a pc you will see the serial device appear when you turn the picocalc on. This is how the serial console works. If you attempt to use the UART0 sockets on the side connector then you will be fighting the CH340. This is unlikely to cause damage but it isn’t going to work properly. You can disconnect the CH340 from the pico with one of the internal switches and free up the UART0 sockets but doing so will also put the keyboard processor into its bootloader mode which is probably not what you wanted.
The UART_1 sockets are connected directly to the keyboard processor and will not be conflicted with the internal switch in its default position. I have no idea if you can read and write data on this port from the pico but if that is possible then it would work electrically.
The USB sockets go directly to the keyboard processor. Flipping the other internal switch will connect the usbc to these pins, presumably so that the firmware can be flashed. Again, I am not sure why you would want access to the usb pins on the keyboard processor in normal use.
I go directly from the side socket pin (which I lifted) to the Pico pin (also lifted) I can’t receive on the USB serial port now but I only use the real serial port anyway. I can still update the keyboard software through the USB serial port on the Pico, just as the instructions say.
I also hijacked those pins to expose the the SWD debug port on the Pico. I agree the pins are not useful as is.
Has anyone tried fitting 21700 cells into the PicoCalc?
hopefully not into the side sockets
