Hullo! Welcome to the forums. I found this using the search function:
That said, it’s comparing a pretty old raspberry pi. It’s up to the RPi 4, which is quite the beast but also costs significantly more.
That said, that table is referring to the older cpi board without HDMI and half the RAM.
At the end of the day, you’re getting an ecosystem with integrated peripherals with the CPI. Some things are cross compatible with the RPi; some things aren’t.
