WonderSwan is one of the systems that runs nicely in the usual emulator cores on the uConsole and GameShell, and its vertical-play games suit a handheld you can turn sideways. Some people end up wanting the original hardware too, to compare against or to collect. The OneMall team (a Japan proxy-shopping service, disclosure at the end) put some notes together on buying one from Japan, since almost every console and cart is sold there and the listings are in Japanese.
Which model
| Model | Screen | Good for | Watch for |
| WonderSwan (1999) | Monochrome reflective LCD | Original library, low prices, many shell colors | Faint display, polarizer aging, missing battery cover |
| WonderSwan Color | Reflective color LCD | Color library on a lower hardware budget | Ghosting, dim viewing angles, worn power switch |
| SwanCrystal | Reflective TFT color LCD | The clearest stock screen | Higher prices, scratches, replacement shells |
| IPS-modded unit | Illuminated replacement panel | Indoor play | Install quality, shell cuts, extra power draw |
SwanCrystal is not backlit; a lit screen means the unit has been modded. Listings sometimes spell it “WonderSwan Crystal”. It is also worth separating original monochrome games, dual-compatible titles and Color-only carts before buying, because a Color-only game needs Color or SwanCrystal hardware.
Search terms that work on Japanese marketplaces
- ワンダースワン (WonderSwan), ワンダースワンカラー (WonderSwan Color), スワンクリスタル (SwanCrystal)
- 動作品 - tested working. 動作未確認 - untested, which is not the same as working.
- ジャンク - junk / sold as-is. Often the lowest price, and sometimes a reasonable donor for a screen mod.
- 本体のみ - console only. 箱付き - with box.
What to ask for before paying
- Powered photos of light and dark scenes (lines, blotches, polarizer damage).
- Repeated cold starts, since worn power switches can be intermittent.
- Both the horizontal and the vertical button clusters tested, not just a menu.
- Close-ups of the battery compartment for corrosion, and whether the battery cover is there. Missing covers are common and replacements rarely match the shell color.
- For IPS mods: which kit, brightness control, shell cuts and battery behavior.
Most of the library is Japanese text. Low-text puzzle, action and shooter games (Gunpey, Judgement Silversword, Dicing Knight) are easier to play than RPGs like the Final Fantasy or Digimon releases. A translation patch online doesn’t turn an original cart into an English one.
Costs, if you use a proxy
With OneMall the service fee is ¥300 per item on most marketplaces and from ¥200 per item on Yahoo Auctions and LinkBuy. The first six orders consolidate free (¥100 per order after that). Storage is free for 90 days after arrival (30 days after consolidation). A wrong/missing-item check is ¥200 and unboxing photos are ¥500 or ¥700. Those photos show what arrived at the warehouse; they are not a repair diagnosis, and OneMall does not independently verify originality or guarantee condition. International shipping is charged on the greater of actual and volumetric weight (L x W x H / 5000 in cm), so a console, a couple of carts and a case from one seller usually ship cheaper together than separately. For US addresses the current carriers are ECMS, DHL and Japan Post EMS (DDP); the live quote is what counts. Since August 29, 2025, US-bound parcels of any value go through customs and pay applicable duties, taxes and fees - the $800 de minimis exemption no longer applies.
The full write-up, with a game table and FAQ, is here: WonderSwan buying guide: Color vs SwanCrystal and games. Disclosure: OneMall is a commercial Japan proxy service and that article is the source for this post.
For the uConsole owners here: which core are you running WonderSwan on, and does vertical mode work for you on that screen?
