I downloaded and installed the “4do” 3DO core through the “Download core” menu in RetroArch but it doesn’t load. I get no error or anything on the GS screen, simply doesn’t load. I get back to the core list menu as if it had loaded, but on the “status bar” on the bottom it either says “No core” or sticks to the previous loaded core.
Indeed. I didn’t even know about this console, don’t know why, I discovered it since searching for games for the GS, and indeed it has several games I want to try!
The original core for download does crash, I did compile from github 4do source, this one is working. However I have not yet managed to start a game. I have all that seems to be needed at the right places, but the game is not started.
Oh, that’s a shame. I never compiled this from source and can’t see any instructions. Is it just a case of running ‘make’ and copying the resulting file to the cores folder?
I assume you have a stock GS installation, maybe already updated to launcher version 1.21, however that should not be required.
The following steps include commands to be type to the ssh console as they are shown below. This means all on one line, upper and lower case are important, every tick, slash or backslash counts. A command is executed once return/enter key is pressed. Hence you may simply copy/paste them from here into your ssh terminal windows and hit the enter/return key after each single one.
Steps
Connect to GS with ssh
Type the following line into the terminal window, followed by return key to execute it:
Now start RetroArch from main menu and quit it again
In Retro Games you will now find the new entry 4DO
Once you have copied one of the BIOS files to games/4DO you can actually start the emulator. In Retro Games select 4DO then choose the bin file of your BIOS. It will start then ask you to enter a disk, that is where I am stuck for instance.
I got it to load! You must first place the BIOS file (panafz10.bin) into ~/games/retroarch/system (or whatever folder is defined as the “System” directory in Retroarch settings). Then place your game iso into the ~/games/4DO folder.
@lasvegas thank you for these details. I noticed that when only starting a BIOS, the animations look quite slow, guess the core is not optimised for ARM. I will check the few games I have as soon as I find time.
Hi everyone, I found this topic and I want to know which one is the best 3DO Emulators, I want to start playing again 3DO games. If someone is still reading this topic let me know your best solution for installing 3DO Emulator.
Hi gema, I don’t think you can play 3DO properly on the clockworkpi, at least I couldn’t do it when I tried back in October, and not much has changed since then.
Just one quick question because I’m new to this forum and to emulators and games playing on pc and not on original consoles. Want to Play 3DO Games my question is reading thru this thread 3DO is an emulator or just a code that can be inserted on RetroArch and play the 3DO on RetroArch?
