Here, you can talk about Astralixi, development updates will be shared, and more.
Astralixi is a user-space, not an operating system, targetted towards space enthusiasts, with a Terminal User Interface. It supports ARM linux devices with systemd, and has quaterly releases (January, April, July, October).
Minimum Requirements are low, about 128mb of storage at a minimum, and 256mb of memory on your device. These are just minimums, not reccomended.
I have finished coding the shell for the first pre-release, and now I only have to integrate the kernel with the interpreter, and run a script for running my shell code.
After the release of this version, I may take a break from the OS, for maybe 2 weeks and come back to it right after.
Hey guys, I finally have a .img for Astralixi OS, but I’m stuck because I can’t actually test it yet.
USB booting isn’t working at all for me. I tried to use a VM instead, but it just breaks. It either opens a window that stays black and pins my CPU at 100%, or it just does nothing while the CPU goes crazy. I tried doing a no-graphics boot too, and that sometimes works for a bit-it lists a bunch of stuff in the terminal, but then it just freezes 7 seconds in while it’s “looking for” something.
Since I can’t get it to actually boot on my setup, I was wondering if you guys could help? If anyone knows how to fix this or wants to try testing the image to see if it works for you, let me know!
I got Astralixi OS on a micro sd card, and when I tried booting, it just showed a black screen on the uConsole.
The binary of Astralixi OS works completely fine, so it’s either something to do with how I built the kernel (@rex can you help if possible) or the packaging into a .img in the end.
Can’t really remember unfortunately
Just searched it up on google with like specific searching like e.g: “How to compile a custom linux kernel into a basic binary for ARM64”
keep track of what you do, you’re going to have to do it regularly if you want to get this to work. And it’s a lot easier to help you when you can show what you tried
