Backup Uconsole microSD
Just running from SD card at the moment and wondering about backup possibilities.
Tried the Raspberry sd card copy utility in Trixie to copy the sd card to an external memory stick. It took a while (older usb drive) and no errors yet a Linux file system app on my Win10 pc shows 14Gb of the 32Gb used yet no where near 14gb of data visible !. Lots of root files and just one folder visible, same using file manager on the Uconsole ?
you can use in Linux dd - here you can see how to do it https://forums.raspberrypi.com/viewtopic.php?t=46911
You can’t view both partitions on the SD card with windows. You just see the boot partition and not the root partition.
Not totally true. I’m using Paragon ‘Linux file system for windows’. Today for some reason I see two drive letters, F:rootfs and G:bootfs. Much better lol…
