I’m having difficulty upgrading my Devterm, and uconsole, as follows:
flashed OS onto Lexar 256Gb micro sd, just following the recipe. Removed 16Gb ssd card from Devterm, installed 256Gb - won’t boot. Tried it in my uconsole - won’t boot. Since I did everything right as usual, it must be the Amazon cards I got.
Ordered PNY 128Gb micro sd card from Amazon, flashed per recipe - Devterm won’t boot with it, neither will the uconsole.
Assuming it was the card again, I ordered a pre-flashed 128Gb card from vilros. Surely that would fix it - alas know. Neither Devterm nor uconsole will boot!
What am i doing wrong? please tell me i just need to press some reset button or short some jumpers or whatever…
Devterm and uconsole both have aarch64, Cortex-A53.
Goodness! I have wasted so much time on this. Thank you for responding. If I may - will itbwork on a 256Gb card? What brand should I use? How do I get the image onto the card?
Sorry for the dumb questions - they are genuine though!
Next question - sorry! I also ordered a microsd to usb adapter. I can see and open the bootfs and rootfs in the file manager. Can i copy over the drivers fron the devterm into the right directories on the vilros card? Do the same for my uconsole?
What are the files/drivers?
Downloaded bookworm.xz.
Used 7-zip to extract.
Used some flasher I downloaded to flash to the Microsoft.
No boot on Devterm oe Uconsole.
Qsame result with Dragon.
Are there other steps?
A specific image I should use?
Do something different because aarc64 cortex-A53 could?
Best Regards,
M
