Bluetooth - any tricks?
Hi
I received my unconsole last week - and I’ve been experimenting with it.
I have the CM5 board in… and can’t seem to get a bluetooth keyboard/mouse paired with it. Any tricks to make that turn on? Wifi works.
I am running now, the ClockworkPi-Ubuntu-24.04-6.12.45.img
Looking at USB/PCI - should I see bluetooth?
root@uconsole:/# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 1eaf:0024 Leaflabs uConsole
Bus 001 Device 005: ID 17ef:6099 Lenovo Lenovo Traditional USB Keyboard
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
root@uconsole:/# lspci
0002:00:00.0 PCI bridge: Broadcom Inc. and subsidiaries BCM2712 PCIe Bridge (rev 30)
0002:01:00.0 Ethernet controller: Raspberry Pi Ltd RP1 PCIe 2.0 South Bridge
root@uconsole:/
I have the “lite” version if that helps?
Thanks
Sean
lite is only about ‘emmc vs sdcard’
do you have ‘wireless cm5’? what model number?
do you have a wifi?
you should have a bluetooth icon in system tray, can you please run in terminal:
$ sudo bluetoothctl list
$ sudo systemctl status bluetooth.service
This what I ordered in terms of CM5:
5542-SC1598 Raspberry Pi Compute Module 5, Wireless, 8GB RAM, Lite - CM5108000
The bluetooth icon shows up, but it doesn’t find anything.
did you connect your wifi/bluetooth antenna to cm5? not to the mainboard?
does your wifi works?
Antenna is connected to mainboard..
What’s the output from these commands.
antenna should be connected to CM5
Awesome that worked!!
